Pontiac Firebird 1967-2002 - Did our cars come with a power steering cooler?
RedVertTA
11-02-2011, 10:45 PM
I've heard from one source that all the ls1 fbodys came with a power steering cooler, then another said only ws6 cars got a power steering cooler. Which is it?
Mumbles
11-02-2011, 11:25 PM
Just brought home an 2001 Formula (Non WS6) this evening that has a Power Steering Cooler. I have a 2000 WS6 Formula that has one and my brother's 02 SS is equipped with one as well. But the 1999 Formula (Non WS6) in my signature doesn't have one. This leads me to believe it doesn't matter whether the car is a WS6 or not.
Many guys choose to delete them, due to the fact that they are prone to failure. When they do fail, you end up with Power Steering Fluid in your Radiator and Antifreeze in your Power Steering Reservoir. Not good. My brother and I plan to eliminate them from his SS and my WS6 for this very reason.
myk
11-03-2011, 04:10 AM
The SS's and WS6's came with them; later during production, not sure when, I believe all V8 F body's came with the coolers. Someone correct me if I'm wrong...
99'CajunFirehawk157
11-03-2011, 06:14 AM
In this first pic is the factory "cooler" your speaking of,
if you have one like this (the long tube looking part connecting the two top rad hoses) take it out ASAP and avoid much misery and p/s fluid mixxed with your coolant.
Do a search and see how many fail...
https://lh5.googleusercontent.com/-L4mr72pEYEo/TrJ2gNY6_2I/AAAAAAAAF8w/P1Rum_CexTY/s800/mcnordta%252520011.jpg
And then spend $50 on parts, add one like this and you will truly have a p/s cooler...
https://lh5.googleusercontent.com/-35dTS_DvnHw/Tmuk6QSQivI/AAAAAAAAFLw/h5Y9WGUATpQ/s1024/IMG_0990.JPG
Much info on this subject on this forum, search. :usa:
RedVertTA
11-03-2011, 09:02 AM
^^^ Mine doesn't have that tube on the radiator hose so I guess I don't have the cooler. What parts are required to add a power steering cooler? I'm tired of having fluid boil out of my reservoir.
99'CajunFirehawk157
11-03-2011, 10:02 AM
Ya just need a trans type cooler like shown and some extra p/s hose, maybe a few fittings, nothing major...
RedVertTA
11-03-2011, 10:36 AM
^^^ Can I ask you what are the dimensions of the cooler you used? And what kind of clips are those holding it in?
99'CajunFirehawk157
11-03-2011, 10:44 AM
http://www.amazon.com/gp/product/B000C39C86
the mother of all fbody ls1tech power steering cooler info threads...
http://ls1tech.com/forums/general-maintenance-repairs/1343182-power-steering-cooling-success.html
RedVertTA
11-03-2011, 11:46 AM
^^^ Wow, I never saw that thread. Thank you very much for the links and info.
Paul Bell
11-03-2011, 08:27 PM
My '99 TA did not come with the POS cooler...er, I mean the PS cooler. Thankfully.
myk
11-04-2011, 03:39 AM
Wait a minute. Based on where the stock cooler is located how is that supposed to cool the fluid?
BOBS99SS
11-04-2011, 03:41 AM
agree with cajun , i had hell with mine
Paul Bell
11-04-2011, 05:16 AM
It works just like the stock transmission cooler.
99'CajunFirehawk157
11-04-2011, 05:40 AM
Like a lot of things on our cars that factory POS may have actually heated up the fluid more then it did cool it...:mad: I can tell you this, when I installed my new cooler, I layed under the car for at least 20 mins checking for leaks and was amazed how hot the tubes on the new cooler got just idling in the garage....:nod:
babbage1109
11-04-2011, 08:17 AM
My 01 didn't have one.
firemech21
11-04-2011, 10:23 AM
My 99 t/a, came with a cooler. Honestly I talked to a couple different stealerships and it all depended on who speced out the RPO codes for the car. So if they wanted the cooler it was an extra charge/option.
JohnnyBs98WS6Rag
11-07-2011, 11:34 AM
RPO V12 (COOLING SYSTEM,POWER STEERING FLUID P/S CLG SYS(V12)) was originally installed (as standard equipment) only on SS and WS6 cars in '98, then it became a option on cars other than the SS and WS6s in '99-'01, then all LS1 F-bods got them in '02.
41863nj
11-15-2011, 12:01 AM
my 2000 WS6 has it...
Cool28
11-22-2011, 04:31 PM
Hmm I bet I could use my old stock trans cooler for a powersteering cooler
cpop98ta
11-24-2011, 06:21 PM
I also got rid of the factory cooler and mounted a new one in front of the radiator.
http://i1142.photobucket.com/albums/n602/cpop98ws6/117.jpg
