full exhaust and 243 heads,what cam
a4 3:23 full weight thinking 3200-3400 stall 224r, 224-228 ,230-230,tourquer v2 or that street sweeper cam? Or anything along those lines,purly a street car but want to bust some *** in it,will have ls6 intake soon,
has l/t tsp ory and magnaflow catback/lid
i would run a TSP 233/239 cam with a 3200 stall... should pull nice an hard and take down most things you come across on the street and if you can tune really good it will behave relatively docile, until you punch it! (112lsa would be my choice but maybe 114lsa for easier tuning). just one mans opinion, im sure others will have theirs.
LS1Tech Premium Sponsor
Personally I would recommend a 3400 Converter with a TorquerV2 on a 112 or 114. We've seen this combination at least 100 times with great results.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
whats the biggest cam i can run with the stock 98 injectors? I keep reading 228r but im really liking the v2 cam,why dont anyone suggest the v3 tourqer?
what lsa should i run?i dont want to spin much above 6500 till i get these rod bolts
you can run 233/239 cam with stock injectors (if they are the same as the corvette injectors), they will be at about 95% + duty cycle but they will work just fine. 112 LSA or 114 LSA, the wide the LSA typically the less overlap that the valves will have, less overlap (114 LSA) = smoother idle, more overlap (112 LSA) = rougher idle and is also harder to tune... i would not advise you going any tighter than 112 LSA for a street driven daily driver, anything tighter will be very difficult to tune and will give you alot of "bucking" if not tuned properly... 112 lsa will sound a little meaner than 114 lsa
