Street Sweeper HT Cam
Old 11-05-2011, 07:17 PM
mac62989's Avatar
Default Street Sweeper HT Cam
Looking for imput from those who run this cam(228/232 .600/.612 111 LSA). I searched but didnt find a whole lot other than the 111 LSA sounds badass, mostly it was threads about its bigger brother. I plan on going with AI 243s and I was always a fan of EPS cams and recently talked with the guys over at AI who do their own cams which sound very promising as well. The Street sweeper just really intrigues me. My car is a weekend toy that isnt raced. Looking for nice low-range torque. If anyone can share their experience its greatly appreciated.
-Matt
Old 11-05-2011, 08:34 PM
Paul57's Avatar
My EPS cam is nearly identical to the Street Sweeper HT but I haven't started the motor yet...which sucks. Although it (Sweeper) does sound good on You Tube. I was wondering what type of power was being made with the Sweeper HT but am fairly certain the EPS will be stronger from other EPS results I have seen. My EPS is 226/230 111+4 with 600-ish lift. I am carb'd so there are no worries about the 111LSA for me. I was thinking at least 500chp and am built for (street) torque also.
Old 11-06-2011, 11:15 AM
mac62989's Avatar
Whats the problem with 111 LSA? I have only seen great things out of EPS cams and thats why I wanted one. The guys at AI told me their cams have more of a potential to make power and will be better matched to the heads than an EPS cam. I just havent seen alot on their cams like I have EPS. They reccomended me a 228/234 .600/.600 110-114 LSA's. The Street Sweeper HT just sounds exactly what im looking for. Not worried about sacrificing a little power up top if it has a strong low-midrange torque.
Old 11-06-2011, 12:05 PM
Paul57's Avatar
I have heard that it is harder to tune than something a little wider. But, if you have a good tuner there is nothing to worry about.
I have only seen great things out of EPS cams and thats why I wanted one. The guys at told me their cams have more of a potential to make power and will be better matched to the heads. I just havent seen alot on their cams like I have EPS. They reccomended me a 228/234 .600/.600 110-114 LSA's. The Street Sweeper HT just sounds exactly what im looking for. Not worried about sacrificing a little power up top if it has a strong low-midrange torque.
The EPS guy (Geoff) is extremely knowledgable and I do believe his lobe design has a slight edge in making power. You are making a good choice by looking for low-mid range torque in a street car.
Old 11-06-2011, 12:47 PM
mac62989's Avatar
Ya im not worried about top end when I wont be using that on the street. Not too sure on tunes yet. Nothing that close to me. Slowhawk, New Era, and East coast superchargers are all within range but nothing is closer than 2 1/2 hours away..
Old 11-06-2011, 01:20 PM
Rise of the Phoenix's Avatar
The Streetsweeper HT cam will be a great cam. It's was created by cam master, Ed Curtis, who may be the most knowledgable person on the planet regarding cams. Not to mention the lobes used are his own proprietary lobes.
Old 11-06-2011, 03:11 PM
99Bluz28's Avatar
The 111 lsa shouldn't be any problem for a good tuner, Have you considered going with a custom grind; that's what I did. PREDATOR-Z speced me a 227(.614")/231(.617") 111lsa+2 w/LSL lobes. If you want to minimize valvetrain noise(mine's noisy) then go with a 230(.609") with LXL exhaust lobes
Old 11-06-2011, 05:17 PM
mac62989's Avatar
I always thought about hitting up Geoff and Pat G for a custom cam. I know EPS cams are known for their quiet valvetrains. Im gonna hit up Phil at AI and see what he reccomends for low-mid range torque.
Old 11-06-2011, 07:18 PM
SWEET98SS's Avatar
I have the larger Streetsweeper that New Era Performance sells and have also heard about the HT, everyone loves it that has it. Do some searches and you will see some results on this forum.
Old 11-06-2011, 08:46 PM
mac62989's Avatar
I searched and pretty much found cam only results but not alot at that.
Old 11-06-2011, 08:52 PM
SWEET98SS's Avatar
Did you see this one? LS6 heads
https://ls1tech.com/forums/dynamomet...0hp-409tq.html
Old 11-06-2011, 09:03 PM
A.R. Shale Targa's Avatar
Pat G. and Geoff specify cams for all sorts of applications and usually nail it
on the head !!! AI will suggest a cam with valve events to maximize the flow
rates of their CNC programs. It's really a win win scenario no matter how you
dice it.
Old 11-06-2011, 09:41 PM
MASS seller approved
low2001gmc's Avatar
i was gonna say refer to that thread also. badass cam ive been wanting but my truck is a daily driver again or else id be putting in my 6.0. should work great with them ai 226 heads.
now you mentioned new era performance as being one of the closer shops for tuning, i would go with them as they particularly sell ed curtis cams so they are very famillar with the streetsweeper ht. refer also to "studderin" on here.
i dont see how you can wrong with the ssht cam and new era performance, a sponsor on here who again is familiar with this cam. good luck with your project.
Old 11-06-2011, 10:04 PM
mac62989's Avatar
Yes I did. Very promising on stock 243s.
Old 11-06-2011, 10:22 PM
mac62989's Avatar
Also take back the part about New Era being close to me. I knew they were in NY but didnt realize how far they are, about 400 miles of 6 1/2 hours. Slowhawk is still the perferred shop for me then.
Old 11-07-2011, 09:02 AM
I would suggest having Ed Curtis spec you out a cam based on those heads. I've heard he and AI work closely together, so Ed will be very familiar with those heads.
If you haven't seen his custom cam spec sheet that you have to fill out, let me tell you, it's extremely detailed; most detailed one I've ever seen. He specked me out a cam based on some AFR 205 heads. I ended up trading the heads/custom cam for a set of wheels and tires (wish now I hadn't done that), but the combo ended up making north of 450 rwhp with a LS6 intake, which is exactly what I told him I wanted in regards to power.
Old 11-07-2011, 09:11 AM
alans02z's Avatar
I had the ht in my 04 z06, I loved it. After the car was totalled, I pulled the cam out and put it in my friends 2000 ss, with stock 241 heads 6 speed and minor bolt ons the car has went 7.46 @ 93 full weight. The thing just drives great. Easy to tune, even with the stock gear in the z06, it was very awesome to drive even in traffic. Predator z actually told me to get that cam for my car, so I knew itd be an awesome cam.
Old 11-07-2011, 10:00 AM
mac62989's Avatar
I wasnt aware of this. I emailed Phil at AI last night mentioning the Street Sweeper and for his reccomendation on a good low-midrange torque cam. Ill be waiting for a response from Phil. Thanks for pointing this out.
Old 11-07-2011, 06:29 PM
low2001gmc's Avatar
oops but initially you expressed an interest in a streetsweeper ht and above you mentioned street sweeper to phil at ai. these are clearly two different versions with the ht (high torque) being more geared for a street strip vehicle while the street sweeper is more race oriented. the ht has proven to put down better numbers than the bigger version also. impressive.
Old 11-07-2011, 07:03 PM
mac62989's Avatar
Ya I meant the SS HT I just forgot the second part. I provided the specs of the HT to Phil as well, just waiting on a response now..
Quick Reply: Street Sweeper HT Cam
