can you mix tranny fluid?
Old 11-06-2011, 09:51 PM
Floorman279's Avatar
Default can you mix tranny fluid?
a year ago i had my 1998 t56 at the dealer for some tranny work........they replaced it with new fluid not sure if it was dexron 3 or syncromesh......im in the middle of installing my s60 and a new racetronixpump......with the driveshaft and rear out of the car, i started my car to see if the new pump was workingbefore i put the rear in.........i let it idle for a bit and a good amount of fluid came out of the rear of the trans where the driveshaft is....so id like to throw just a little fluid in it......but again, not sure if they used dexron 3 or syncromesh......if im only adding id say 4-8oz, can i throw either in?
Old 11-06-2011, 10:06 PM
also, where can i find GM DEXRON III
Old 11-07-2011, 01:15 AM
jmd
jmd's Avatar
That should be fine. Use the fill plug on driver's side.
Valvoline still sells a Dexron III/Mercon fluid. Many others have gone to Dexron VI which is backwards compatible in automatics.
Old 11-07-2011, 10:43 AM
can i mix brands since im only using a little
Old 11-07-2011, 11:02 AM
87gnx's Avatar
yes brands, NO on mixing weights.
Old 11-07-2011, 10:36 PM
so any brand dexron will work
Old 11-08-2011, 07:13 AM
Kleeborp the Moderator™
MeentSS02's Avatar
If it meets Dexron III specs, it meets them. Just pour it in and go.
Quick Reply: can you mix tranny fluid?
