4l60E & Dakota Digital gauges
Old 11-09-2011, 10:38 PM
veltboy618's Avatar
Default 4l60E & Dakota Digital gauges
I have been searching the internet & I cant find nothing on how to make my DD gauges work with a 4L60E trans. Im sure its a way to get gauges to pick up the speed signal from the computer. Has anyone done this before?
Old 11-10-2011, 06:26 AM
LS1MCSS's Avatar
Well, we need more info, like what year motor and are you using the stock computer? If so, just connect to the speedometer output from the pcm.
Old 11-10-2011, 08:30 AM
veltboy618's Avatar
The engine is a 2002 & yes I will be using the stock computer.
Old 11-11-2011, 05:44 PM
flywheel's Avatar
I put DD in my 71 velle, w/4l80e. I told them what I was doing and everything came with it.... I didn't have any trouble setting it up. I did get the gear indicator accessory. It was all strait forward, just followed the instructions... Ialso got their cruise control,and rear view mirror..Cool stuff...
Rick
Old 11-11-2011, 06:00 PM
veltboy618's Avatar
Rick
I was trying to figure out how i will hook the speedo up now that I'm using the 4L60E instead of the TH350 with the speedometer sending unit that screws onto the transmission.
Old 11-11-2011, 09:03 PM
futureuser's Avatar
The Dakota VHX gauges count the vss pulses for one mile to calibrate the gauge. Or they have the mechanical screw in speedo that converts to a pulse signal. Not sure how the older ones work, but their tech support is pretty good.
Old 11-11-2011, 09:21 PM
XpEdItIoUs's Avatar
You will have to run a wire from the PCM vss out, Pin 55 dark green/white to the digital dakota box.
Old 11-11-2011, 09:48 PM
veltboy618's Avatar
You the man!!!! Thanks a lot
Old 11-11-2011, 10:47 PM
XpEdItIoUs's Avatar
Then just follow the instructions that come with the digital dakota to program it to read it correctly.
Old 11-11-2011, 11:02 PM
cutlass_455's Avatar
My DD gauges installed easy. I used the VSS output wire, just tapped into that and programmed the DD computer with the up and down buttons. I just followed the instructions that came with the gauges.
Old 03-17-2013, 02:07 PM
thunderstruck507's Avatar
Just installed these and tapped the vss purple wire at the trans.
Now the PCM is throwing a low signal code from the vss.
Do I have to use the vss out pin in the PCM or is something else wrong.
EDIT: went back and followed directions above to tap the pin 55 green/white wire instead and now everything works perfectly
Quick Reply: 4l60E & Dakota Digital gauges
