19x12 c6 rims fit??
Old 11-10-2011, 09:44 AM
trans665's Avatar
Default 19x12 c6 rims fit??
im looking at two c6 19x12 rims and Hoosiers R6 345x30 tires, but my drama is will they fit my 1999 z28 rear???
Old 11-10-2011, 12:44 PM
SSCamaro99_3's Avatar
Considering that most 315/11in wheel combos in these cars require bfhing the inner wheel well and rolling the fender lip, and you want to add an additional inch of wheel and 1.18inches of tire, I would say you have some work ahead of you.
Old 11-10-2011, 01:51 PM
VinR1's Avatar
short answer: no
you're like the 3rd or 4th person this week to create a thread asking that same question. You dont even need to search, just scroll down
Old 11-10-2011, 08:52 PM
badfbodyz's Avatar
Originally Posted by VinR1
short answer: no
seeing that there is a thread about this just a little further down from this one, i think maybe YOU shouldve read through https://ls1tech.com/forums/wheels-ti...en-camaro.html before you stated that. look on the 2nd page. there are pics and even says they didnt even have to run any spacers b/c of the offset. all that was needed was grind down the bump stops...he probably did the BFH too although he never mentioned it. he does have a 305 tire instead of a 345 though...
Old 11-10-2011, 10:49 PM
VinR1's Avatar
...in other words
OP, go ahead and get 'em. As badfbodyz just showed, they'll fit just fine. Nevermind the fact that you'll be using tires almost 2" wider in Camaro fenderwells that are known to have less room than TA rear fenders. Good luck.
Old 11-10-2011, 11:20 PM
badfbodyz's Avatar
at the end i clearly stated that the black TA had 305s not 345s....in other words. the title says 19x12 c6 rims. i am saying that the wheels work. not the tires....
Old 11-11-2011, 02:15 PM
zacht's Avatar
yeah. ill be trying to find some 325 or 335s soon. to make them fit. yes bfh mod, and modify your bumpstops and they fit.
they will work
Old 11-11-2011, 06:43 PM
hotjohnnyls1's Avatar
trust me they won't fit and be drivable lol i bought some and cut the bumpstops out hammered the **** out of the fender well and they barley fit! they still rubbed when i hit corners at decent speeds with a smaller spacer they would have fit perfectly
Old 11-12-2011, 08:00 AM
Captain Double Post
BOBS99SS's Avatar
i know you can get them to work i have seen it a few times,
Old 11-12-2011, 02:14 PM
zacht's Avatar
yup! believe what you want about making them fit. i put pics up...which is pretty good proof...
Quick Reply: 19x12 c6 rims fit??
