Flywheel flex??
Flywheel flex??
How much if any, can a flywheel flex (on the outer most edge) when the clutch is being disengaged (clutch pedal pushed in). Especially with a heavy clamping pressure plate??? Flywheel is a monster SFI 28lb billet steel... Only mentioning manufacturer to further describe particular flywheel...Thanks
Give me a call if you're having some issues and we'll answer all your questions you may have.
