General LSX Automobile Discussion Non-technical LSX related topics.
what should i do??
Old 11-13-2011, 02:24 PM
14k
14k's Avatar
Default what should i do??
i found out my car was in a wreck and the strut tower was pushed in so i wont be able to get it aligned right. the alignment guy said he did his best but the front tires sit / \ when looking from the front of the car. the drivers side tire is .5in from being completely flush with the fender while the pass. side tire is about 1.5in pushed in. the alignment guy also said i could take my car to a body shop to get the strut tower pulled out but there would be no guarentee that they could get it back 100%, which i dont like.
i know a guy that runs a dealership with alot of parts cars. some with no damage other than blown engines. all v6 bodys. they have everything except engine/trans but not titles. if i buy a rolling chassis to swap my stuff in how would i go about getting it titled?
or should i just sell the car and start over with a new car?
Old 11-13-2011, 03:06 PM
dee99gt's Avatar
that blows.. if it were me i'd sell it and buy something else..
Old 11-13-2011, 05:06 PM
14k
14k's Avatar
idk now i eyed my tower to headers and compared to my friends TA it looks the same. ill break out the tape measure to double check. what all under the car is adjustable to try to get everything straightened up? car is BONE stock besides my LTs
Old 11-13-2011, 05:10 PM
tt383lt1's Avatar
do a cross mesurement from the same place on both strut towers to the front radiator support and see how far it is and do you have a autobody school around they will pull it for free unless you need a new strut tower. ive done them befor there not that hard to replace them with the tools but you should mesure it and post it.
Old 11-13-2011, 05:27 PM
14k
14k's Avatar
how do you replace the tower if it needs it? cut and weld a new one?
19.5in on the passenger outside (closest to fender) bolt to a bolt on the radiator support.
19.5in on drivers side outside bolt.
20in to from the inside (closest to engine) passenger bolt to bolt on radiator support.
21in on the drivers inside bolt.
Old 11-13-2011, 05:34 PM
RedHotG8's Avatar
Body shops should have no problem straightening out the strut towers. With the tools they have these days they can do amazing things to a wrecked car.
Old 11-13-2011, 05:40 PM
ULTIMATEORANGESS's Avatar
id get an estimate/opinion on what can be done.
i wouldnt sell a car like that to someone without telling them.that seems unsafe.
Old 11-13-2011, 05:46 PM
14k
14k's Avatar
car was sold to me that way without telling me. i just thought it was the cheap drop springs causing it.
Old 11-13-2011, 05:56 PM
tt383lt1's Avatar
they can pull that is there and cracks or kinks ive pulled cars that were 8" off apart and cut two cars and welded them together . and yea if it come down you cut the stock spot welds and replace it at the stock seams. but they can pull that for sure. if there no rips or kinks. id look at the front bumper support and see id it swong one way. i get a esstiment for sure and see how far and were else its bent.
Old 11-13-2011, 06:05 PM
14k
14k's Avatar
ill swing buy a get an estimate on wednesday. its a clear title no wrecks or nothing on carfax guessing he paid out of pocket to repair.. bastard..
Old 11-13-2011, 06:38 PM
nmbr5ml's Avatar
If you did a carfax check before buying it, they have a buyback guarantee. I don't know the details but you might look into that and see if it applies to your situation.
That is of course, if the car was actually in an accident. Are you able to establish that in any way or are you solely getting it from the dude who tried to align your front end?
Old 11-13-2011, 06:46 PM
RedHotG8's Avatar
If the accident wasn't reported Carfax won't stand behind it. Can't expect them to take the blame for something that was unreported.
Old 11-13-2011, 07:57 PM
14k
14k's Avatar
That is solely from the alignment guy.
Old 11-13-2011, 08:00 PM
14k
14k's Avatar
What other than a wreck would cause the wheels to lean and the drivers side wheel to be closer to the fender than the passenger side?
Old 11-13-2011, 08:10 PM
Zlow28's Avatar
yeah i agree with the estimate part, but unless they can make it as good as new, id start looking for another car. Other than safety reasons, it might just start causing more problems (big or small) in the future.
Old 11-13-2011, 08:11 PM
RedHotG8's Avatar
Worn suspension parts can cause that, and hopefully the alignment guy checked that out and knows what to look for.
Old 11-13-2011, 08:31 PM
14k
14k's Avatar
i put new tie rods and ball joints recently so thats all thats new up there. as i told yall a while back previous owner has cheap *** drop springs up front.
RedHot- when you say worn parts what are you thinking like what specifically?
Old 11-13-2011, 08:34 PM
RedHotG8's Avatar
Strut mounts or the struts themselves and control arm bushings could be worn. It's possible the drop springs are throwing off the geometry of the suspension too.
Old 11-13-2011, 08:37 PM
14k
14k's Avatar
struts and springs are new. forgot to add that. up top where the struts bolt to the tower is the nipple supposed to be perfectly in the center? is there a package deal i could buy all the bushings as a set or have to buy indiviually?
Old 11-13-2011, 08:40 PM
RedHotG8's Avatar
If the struts aren't centered more than likely the strut mounts are worn out. They should always be replaced when new struts are installed.
Quick Reply: what should i do??
