Wich t56 magnum ratio for 4:11 diff
Old 11-15-2011, 09:37 AM
Turboswede's Avatar
Default Wich t56 magnum ratio for 4:11 diff
I will buy a t56 magnum from American Powertrain for my project that will be used allround = street,track,drag and just play with.
But I donīt realy know what of the ratios that would be best for me of this 2.
First one is this.
1 2.66
2 1.78
3 1.30
4 1.00
5 0.80
6 0.64
The second one is.
1 2.97
2 2.10
3 1.46
4 1.00
5 0.76
6 0.50
Please need som advice.
Old 11-15-2011, 11:03 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
What kind of car and what kind of HP?
Andrew
Old 11-15-2011, 11:13 AM
Turboswede's Avatar
Itīs in a nissan sportscar I will use a std lm7 engine first with about 280-300hp and put a turbo in later for about 700-800hp
Old 11-15-2011, 11:47 AM
Well, if you were going to keep it NA, I would recommend the wide ratio. Since you are planning a turbo in the future, the close ratio will work better. With that much power, 2.97 1st gear, and a 4.10 rear, the wide ratio will be useless.
Andrew
Old 11-15-2011, 12:28 PM
Jeremy@RPMTransmissions's Avatar
Yea like Andrew said, the 2.66 ratio will be a lot better for your needs. The 2.97 ratio will be more apt to spin the tires and not load the turbo as well.
Old 11-15-2011, 12:47 PM
Kleeborp the Moderator™
MeentSS02's Avatar
So with the 2.66 1st gear ratio, are you stuck with the 0.80 and 0.64 5th and 6th ratios? I've half considered stepping up to a Magnum, but if I have to alter the 5th and 6th ratios to retain the same 1-4 ratios I have in my T-56, that would make the deal a little less exciting.
Old 11-15-2011, 01:03 PM
No, with the 2.66 trans you can opt for the .74/.50 gearset. If you choose the 2.97 trans you are stuck with the .74/.50.
Quick Reply: Wich t56 magnum ratio for 4:11 diff
