Want power
Want power
Here is the deal guys my dad as a Z06 with around 430 horses. Im tryin to get around either 450 horses outta my 02 SS . What is the cheapest and most reliable way to get that kinda power. Oh and i dont want nitrous. I would like to be spendingabout 4g's could you guys tell me what i need and what i will have to do to the car to make sure the power wont deystroy anything.
Good luck ...
If you are talking 430 Engine HP .. You should be able to do that with stock heads .. just a cam, pulley, headers, lid and tuning ..
Crowley
If that is your goal get a cam and long tubes. That will get you close to 450fwhp. If you want to make sure you don't break things get a 12 bolt. If its an A4 (automatic tranny) get a stall put in. If your plan is to beat the Z06 in a drag, add some drag radials and practice launching it.
formula's pretty simple... high flowing heads and the biggest cam you can shove in there with those heads.
and remember, peak HP isn't everything... area under the curve matters as much if not more than peak numbers. Also, all the HP in the world isn't going to do you any good without the proper suspension, gears, tires, clutch, driveline, etc. to put it to the ground effectively.
Lastly, with that kind of power, definitely get a 12 bolt. If you set up a car up with that kind of power to launch properly, you'll grenade your 10 bolt for sure on an M6.
