help with cam
help with cam
I have a ms3 cam, but was wanting to know what lsa is and what it does in sound. Im guessing its the lope. I am wanting a something that lopes. So what lsa sounds the best? Thanks Justin
If the cam in question has no overlap on either LSA then neither may lope. But lower LSA has more overlap, or less negative overlap.
If you are asking specifically in regards to an MS3, then on a 112 LSA it has 15.5* of overlap at 0.050" and on a 114 LSA it has 11.5* at 0.050".
It also depends on if you were to set the idle speeds the same as lope will disappear as you move the idle up.
