b&m pro shift or hurst quarter stick kit for my 4l80e chevelle?
Old 11-21-2011, 11:11 PM
SIKHS 5's Avatar
Default b&m pro shift or hurst quarter stick kit for my 4l80e chevelle?
i was wondering if there is any 4l80e specific kit for my 4l80e transmission... does anyone have part numbers?
do i have to order it for a different transmission(didnt see any listed for the 4l80e) if so which one?
will i need to buy extra parts to get it to work... if so which ones.(which of the two kits comes better suited for the 4l80e)
thanks everyone. ive been searching since the morning, it means alot.
Old 11-21-2011, 11:23 PM
Paul57's Avatar
I've got the B&M Hammer for a 200-4R. Not sure if it works for the 4L80E but it might be worth checking if you are having a hard time finding something.
Old 11-21-2011, 11:35 PM
383lt1impala's Avatar
Get a winter shifter you won't regret it.
Old 11-22-2011, 12:46 AM
Paul57's Avatar
Originally Posted by 383lt1impala
winter shifter
Never heard of one of those...got a link??
Old 11-22-2011, 06:37 AM
forcd ind's Avatar
i have used a couple of the B & M Pro rachets on them, work fine-you have to rem a pin, and use the correct hole in the trans arm, along with installing the shift cable correctly on the shifter housing
the shift cable can go inside/outside the shifter housing, if wrong it throws everything off, fixed a few with that problem, lol
i think they dont really list them for 4L80E's, just 4L60E's, they just havent updated lit.
Old 11-22-2011, 11:37 AM
PontiacFan's Avatar
Use the QuarterStick or ProShift for the 700R4 application, which is the 3160030 model number. Sometimes shown as 316-0030 too.
It's also an A4 style transmission & people in the F-Body world do use them for the 4L60E/4L80E platform.
Old 11-23-2011, 02:34 AM
SIKHS 5's Avatar
Thanks that's exactly what I was looking for. It looks like that part number/every 700r4 hurst quarter stick is on backorder. I'll be going with the b&m and using the 700r4 gate plate.
Old 11-29-2011, 06:34 AM
Sorry I don't go on here much and I hope its not too late but here's the link http://www.wideopendesign.com/Produc...s-Shifter.aspx also I hope the pro shift is different than that pro rachet because I had a prorachet with the 700r4 gate in my jeep before the winters and it would shift like ****.
Old 11-29-2011, 03:28 PM
bmf5150's Avatar
I used the b&m quicksilver in my 68 camaro with my 4l60e,it works great!!!
Quick Reply: b&m pro shift or hurst quarter stick kit for my 4l80e chevelle?
