wastegate 38mm tial
Well thank you both for the info. The sts install paper work sucks big time and looking at my turbo car is a pita and a little different.
What about the wastegate to hit side pipe should there be a gasket there? Does not show one in the instructions but I would think exhaust would leak without one?
I just rehooked up my Tial WG to my hotside and didn't use a gasket although it is a v band clamp. Does your WG come with a little ring that goes on the inlet side of the WG?
Mine is a 2 bolt flange and has a similar ring. But the ring does not fit inside the flange for some reason ... that's why I asked there is a 3mm gap between the 2 flat surfaces. Plus the ring on the WG almost touches the putter edge of the flange. Its a sts pipe with the same tial WG that comes in the kit?
I don't know how to post a picture with my phone
If you got an iphone, download the photobucket app, upload photo to your photobucket account, copy the IMG link and paste it into this thread. Is this a used WG? Have you tried to clean out any buildup that is on the inside of the ring? I had to do that with mine before it would fit inside nice and flush. Also, Tialsport has a diagram for each WG IIRC.
