Anybody Running 5.60's or Faster At 3300lbs?
Old 11-22-2011, 09:14 PM
99 Blue Bird's Avatar
Default Anybody Running 5.60's or Faster At 3300lbs?
I'm curious if anybody is running a 5.60 or faster in the 1/8th. I have a lq4 I want to build and will eventually go to a 370 ci. But for now I want to see if I'm crazy to think I can get there with the lq4 and a turbo. Now I'm sure it can be done but the catch is I have to be at 3300 lbs which to me is heavy but it needs to be done for a class. Is anyone doing this? If so please list your combo.
Old 11-23-2011, 06:26 AM
Fireball's Avatar
plenty of people have run faster than 5.60 @ 3300+
my old setup (366/98mm) went 5.20s @ 3600 lb on very lazy 60 ft times
Old 11-23-2011, 04:26 PM
Dang that's nice. How much boost were you running and what was your CR? What type of fuel were you using
Old 11-23-2011, 05:18 PM
Restricted User
98Z28CobraKiller's Avatar
I've been 5.73 @ 3900#'s in my street car at 23psi. I would think that if I could take out 600 lbs, I could drop atleast 2 maybe 3 tenths to the 1/8th and my car is geared for the 1/4.
Old 11-23-2011, 07:37 PM
That's impressive. You turbo guys make this look easy. Turns out I can go as low as3150 lbs so I'm thinking I can get to 5.60's or faster for sure with a 6.0 and a turbo.
Old 11-23-2011, 08:22 PM
WheelsUp84z's Avatar
nice! I'm running a Real Street 275 drag radial class. Limited to 76mm non billet turbo (single only) and 3400lbs minimum for a turbo/a2w/aftermarket head combo. There's a sbf turbo car in the .30's and Tick's car has been 5.50's so far on a nitrous setup.
Old 11-24-2011, 10:59 AM
yea the organization i was looking at has a limit in turbo size for Limited 10.5(78 mm) but not for outlaw 8.5. i wanted to go nitrous but after reading the weight adds and breaks i can be the same weight(3150) If i go small block turbo with a blow thru and no intercooler as compared to a small block single stage nitrous car(3100) and must add 50lbs for additional stages. i can pretty much make more power with a turbo for around the same price as going nitrous so i might aswell do it.
Old 11-24-2011, 02:41 PM
BLWN1's Avatar
Wow......
Old 11-24-2011, 07:45 PM
cjg454ss's Avatar
i went a 5.7 with a aes lsx and a 101mm on a shakedown run. 18psi
Old 11-25-2011, 01:33 AM
Originally Posted by BLWN1
Wow......
you have something to add?
Old 11-26-2011, 11:34 AM
bad6as's Avatar
been 5.9s at 120. 3275 lbs on 18 lbs 60ft isnt great its in the 1.4s. converter was too loose too. im going for 5.30s
Old 11-26-2011, 12:50 PM
1fast bird's Avatar
I went 5.89 at 3470 lbs raceweight on 15psi. My car is geared for the quarter with 3.25's.
Old 11-26-2011, 01:51 PM
GueSS Who's Avatar
5.30@131 with a 1.24 60ft with a factory APS kit on a 3250lb formula
Old 11-26-2011, 08:02 PM
6 Second Club Moderator
LASTLS1's Avatar
4.9 @ 3460 lbs
Old 11-26-2011, 10:07 PM
bluecar's Avatar
Lets see some fast LQ4 combo with specs.
Old 11-26-2011, 10:13 PM
Nice. Any details on the combo?
Old 11-26-2011, 10:17 PM
Are you willing to let the combo specs out or are you still keeping them on the low like in your build thread?
Old 11-26-2011, 10:21 PM
What exactly is a APS kit?
Old 11-26-2011, 10:24 PM
Originally Posted by LASTLS1
4.9 @ 3460 lbs
Motor Specs and turbo sizes available by chance?
Old 11-27-2011, 09:13 AM
1fast bird's Avatar
Was an ls2 402 with twin tc76's. Had a good bit more in it, but the tune was a little rich. Never got my goal of high 8's before a rod bearing let go and killed the bottom end. Pretty sure it wouldn't have taken anymore boost to get there, just a better driver. Only got 30 or so passes out of it. In other words I never did get comfortable with that setup.
Quick Reply: Anybody Running 5.60's or Faster At 3300lbs?
