05 ctsv 75 or 100 shot
Old 11-23-2011, 10:50 PM
chaseholcombe's Avatar
Default 05 ctsv 75 or 100 shot
I have a 2005 ctsv and it has kooks headers corsa exhaust an k&n intake and tune. So i need a little more power and im a noob to nos have no idea about it lol so i want to do it safe as possible so my questions are:
75 or 100 shot? im all about safe since its my daily driver
dry or wet?
witch kit?
everything i need?
how much hp to the wheels do u usually see from a 100 shot?
its street car i dont plan to go to the track maybe but once or twice lol
in the future im gonna be doing a cam also but for now i wanna go with this, just wanted to get some info first
thanks
Old 11-23-2011, 10:51 PM
itsslow98's Avatar
Do a search and read the stickies all your answers are right there.
Old 11-23-2011, 10:57 PM
i read the stickies it helped me out alot but i still need help lol
Old 11-23-2011, 11:30 PM
karpetcm's Avatar
I like the dry system with 75-100 shot if thats the most your gonna run. Simple install, plugs and a good tune your good to go. You can do the same with the wet setup as well and if you wanna go higher its easier to do so with the wet. Ive done both in the past so in this subject wet vs dry your going to get alot of opinions.
Old 11-23-2011, 11:45 PM
itsslow98's Avatar
Wet 100 shot.
Old 11-24-2011, 08:24 AM
thanks for the replies! slow have u had any problems running it on ur car and do i need to upgrade my injectors or anything like that?
Old 11-24-2011, 08:47 AM
a4ls2goat's Avatar
If you go with a wet kit you don't need injectors, with a dry shot you will need bigger injectors.
Old 11-24-2011, 08:58 AM
cobrakid04's Avatar
are you on stock clutch? If so I vote 75, with a progressive controller.
Old 11-24-2011, 10:52 AM
yes im on the stock clutch and i was worryin about that to.....
Old 11-24-2011, 09:59 PM
itsslow98's Avatar
Im on a stock clutch and have been for about 10 bottles and 15k miles. No problems yet the stock stuff is tougher then most think. I dont launch the car though.
Old 11-25-2011, 06:45 AM
Ph.D. in HUBRIS
custm2500's Avatar
I like wet and the differance between 75 and 100 is very minimal as far as feel goes.
If you want to be on the safe side start with 50 just to get the feel and confidence. Then after some 50 hits jump to 100. If you are concerned about your clutch make sure to set your window switch very consivatively.
100 shot all day long will have no noticable effects on the longevity of the car, as long as it is done correctly.
Old 11-25-2011, 09:37 AM
Slow I'm glad u chimed in cause it make me feel alittle better about the clutch because I never launch ether to much wheel hop for me lol where do u have ur switchs/buttons located at in ur car?
And thanks I think I'm gonna tall to my local shop and see of I can get all the stuff ordered up!
Old 11-25-2011, 09:55 AM
itsslow98's Avatar
nitrous outlet is having a killer sale right now id order from them today. i had a custom switch panel made.
Old 11-25-2011, 10:35 AM
TA1364's Avatar
100 wet shot is pretty simple, I'd go with that. I dont think I'd run a 75 shot with a progressive.
Old 11-25-2011, 10:59 AM
87silverbullet's Avatar
100 shot wet all day long. Colder plugs and pull timing.
Old 11-25-2011, 05:16 PM
100 shot it is lol slow where did u get that from and how much did u pay thanks for all the help
Old 11-25-2011, 06:03 PM
Ph.D. in HUBRIS
custm2500's Avatar
Don't waist your time with your local shop unless you are hardcore about keeping your money local.
You will spend a lot more. And everything you get from NO is as good or better then the big name stuff that is local to you.
Old 11-25-2011, 08:17 PM
i dont really wanna go through a shop anyway the only reason i was considering it is for them to pick me out a kit with everything i need like a heater and whatever else i need? so if yall could help me out with a specific kit i need that comes with everything that will get it going it would help me out a ton! and from what im reading i would like a wet 100 shot so any help would be great thanks
Old 11-25-2011, 08:36 PM
Call these people right here.
http://nitrousoutlet.com/
They have helped numerous guys in this section go fast. They will not sell you something you don't need to make a buck and give you the best customer service before, during and after the sale. They do it all for us. Some guys have even gotten them to build one-off custom nitrous plates for them. They are one of our sponsors, so give them a little play since they are.
Old 11-25-2011, 10:00 PM
87 ill give them a call in the am
slow you have any pics of where ur bottle is mounted??
Quick Reply: 05 ctsv 75 or 100 shot
