07 Heads/Cam/Stall A6 with up-top shifting issues
Old 11-25-2011, 05:59 PM
epic's Avatar
Default 07 Heads/Cam/Stall A6 with up-top shifting issues
Been working a ton on my tune with a few people. When you punch it at any speed under 45, it picks up and goes and I wouldn't change anything about it. Anything above 45, there is a major lag. Here's a video of it lagging:
http://www.youtube.com/watch?v=VxH04dUiRBs
You can see, once it finds out what gear it wants, it hauls ***.
Mods are etp 215 heads, g5x1 cam, 3.42 gear, 2800 stall. Before the heads, it didn't have lag when I got on it from 70, but now.. I'm guessing air changed and we can't find out what the computer wants at all.
Tune file: http://www.visionsconnect.com/sm-21.hpt
Any help would be rewarded with praise as if you were my god.
Old 11-25-2011, 07:41 PM
2TR
2TR's Avatar
Do you have a way to post a log of the issue occuring using Hp Tuners VCM Scanner software?
Old 11-25-2011, 08:50 PM
epic's Avatar
Here's two logs from a tune file back... but the problem was still there, so should be pretty much exactly like my latest tune on there.
http://www.visionsconnect.com/scan1.hpl
http://www.visionsconnect.com/scan2.hpl
Old 11-26-2011, 07:22 AM
GA95DCMSS's Avatar
I seem to have the same problem, but with my 4L60E ever since I put the stall in. Defintely will be watching this closely
Old 11-26-2011, 05:03 PM
2TR
2TR's Avatar
400+ parameters control the A6 transmission. This should be fun! I'll start going thu it line for line. See if anything is OBVIOUSLY not within' spec.
Old 11-26-2011, 05:49 PM
2TR
2TR's Avatar
Not an issue fix just something I've found so far.
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > DESIRED SHIFT TIME > 0, all cells.
Do the same for all (6) of the following sections >
Base Upshift - Normal
Base Upshift - Special
Base Power Downshift
Min Power Downshift
Base CT Downshift - Normal
Base CT Downshift - Special
Old 11-26-2011, 06:02 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > SHIFT TIME INPUT TORQUE ADDER > from 59ftlb.-398 ftlb. of torque and 0 rpm to 6400 rpm, .300, all cells.
Copy the modified table and paste in all Upshift - Normal tables in the Shift Time Torque Adder Section.
In the Upshift-Special table however use the value of .250 instead of .300 as this will give a slightly quicker shift when in the sport/manual mode.
Old 11-26-2011, 06:07 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > DOWNSHIFT- NORMAL > .300 all cells.
For the Downshift - Special > .250 all cells.
Old 11-26-2011, 06:14 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > DESIRED OUTPUT TORQUE NORMAL > 1-2 shift > 0 all cells.
Do this for all of the following Normal, Special, and Downshift tables for each and every gear change option available (DO NOT adjust multi):
Old 11-26-2011, 06:21 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > DISCRETE SHIFT TORQUE > 0, all cells.
Old 11-26-2011, 06:29 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > SHIFT PRESSURE > MAX LINE PRESSURE > D1 to D4 and 1,750 rpm to 7,000 rpm > 180.
DITTO: > D5 to D6 and 1,750 rpm to 7,000 rpm > 155.
Old 11-26-2011, 06:42 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > SHIFT PRESSURE > BASE SHIFT PRESSURE > UPSHIFT - X > 1-2 > load stock values and adjust by +5 until desired pressure reached (I use +15), all cells.
Do the same for all tables under Upshift - X, Upshift - Y.
The 'Vette doesn't technically use a Pattern Z so skip any reference to it.
Old 11-26-2011, 06:44 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > SHIFT PROPERTIES > MAX ADAPT vOL > MIN 2-3 > 200.
Old 11-26-2011, 07:20 PM
2TR
2TR's Avatar
HP TUNERS EDITOR > TRANSMISSION > AUTO TCC > APPLY/RELEASE SPEED NORMAL > NORMAL > 3rd/4th gear only change 0%-75% throttle position > 158.
Do the same for the 5th option as well.
Repeat for ALL shift patterns except HOT (leave stock).
Old 11-26-2011, 07:34 PM
2TR
2TR's Avatar
Open up the HP TUNERS VCM SCANNER > TABLE PRIMARY > CLICK ON HPT ICON (MIDDLE TOP) > RIGHT CLICK ON ANY BLANK WHITE SPACE > INSERT > TRANSMISSION > TCC > TCC DESIRED SLIP RPM.
DITTO : > TCC LINE PRESSSURE
DITTO: > TCC SLIP RPM
You will now have (3) seperate new PIDS added.
Now RIGHT CLICK > INSERT > TRANSMISSION > TRANS CURRENT GEAR.
DITTO: > > TRANS TURBINE RPM
You now have (5) new PIDS total added.
Save config. as TCC Slip Config.
NOW...
Go back to the HP TUNERS EDITOR > TRANSMISSION > AUTO TCC > TCC PRESSURE > APPLY RAMP > from 5 rpm - 400 rpm and 74 ftlb. - 369 ftlb., +10.
SAVE AND LOAD TUNE FILE.
The goal is to get the TCC SLIP to 0-20 rpm. Watch the TCC SLIP readings...if not within 0-20 rpm increase pressure by +5 until results are achieved.
Old 11-26-2011, 07:35 PM
2TR
2TR's Avatar
That's all the info. I have for you! I noticed you have made SOME of these changes already but in different increments. You also have a few other tables that have adjustments but nothing that would cause an issue. Good luck!
Old 11-27-2011, 06:25 PM
epic's Avatar
Wowzer, that's a lot of changes. Thanks for having a look. I was like how did my thread have this many replies already, lol.
Have you ever tuned an A6 before?
Old 11-29-2011, 06:30 PM
2TR
2TR's Avatar
Yes with those (and and few select other tables) exact tables and values.
Quick Reply: 07 Heads/Cam/Stall A6 with up-top shifting issues
