ls1 ring gap for 150 shot
Old 11-28-2011, 09:58 AM
mycool240's Avatar
Default ls1 ring gap for 150 shot
hello all... im in process of rebuilding a ls1, it has stock bore and pistons, has been honed for new rings. top ring is showing .025, bottom ring is showing 0.27... is this too loose or will it be ok ? the motor will see a 150 shot later down the road but will be mostly street driven. thanks too all!!!!
Old 11-28-2011, 05:09 PM
Jontall's Avatar
http://www.wiseco.com/PDFs/Manuals/RingEndGap.pdf
Old 11-28-2011, 05:39 PM
JPH
JPH's Avatar
Those gaps will work.
Old 11-28-2011, 06:14 PM
ls1fst98's Avatar
thats the gap table i used for my build.
Old 11-29-2011, 08:49 AM
mycool240's Avatar
using the table you guys posted im coming up with almost .020 and .022... so what should i do? use the ring i have that are coming out at .025 and .027 or try and get a different set??? thanks for all the help by the way!
Old 11-29-2011, 09:38 AM
ls1fst98's Avatar
I did mine at that spec, but a little looser on nitrous from what I understand isn't a bad thing. I don't know what they consider mild nitrous. Me personally am going to use a 100shot. Hopefully someone with more experience can chime in.
Old 11-29-2011, 12:04 PM
mycool240's Avatar
from what ive searched i have read that a lil loose for nitrous is good but im tryin to figure out how much is too much.. i dnt want to put these in and have bad blow by or compression loss.
Old 11-29-2011, 12:32 PM
ls1fst98's Avatar
I take it you didn't get file fits after it was honed? Just bought stock replacements? What year is the block?
Old 11-29-2011, 01:53 PM
mycool240's Avatar
00 block. there just standard bore replacements sealed power.
Old 11-29-2011, 02:25 PM
ls1fst98's Avatar
You had I honed? Did you check the cylinder bore to see how much they took off?
Old 11-29-2011, 03:38 PM
farmington's Avatar
Your ring gap is dependent on the type of piston you're using. Hyper or forged. Check with your piston manufacturer to see what they recommend. If you're thinking about spraying, you might want to put in some stronger rings.
Old 11-29-2011, 03:42 PM
ls1fst98's Avatar
Since when? Ring gap depends on heat applied to rings and the force because they expand as they heat up. At least that was my understanding. I've never ordered rings and had them say ones for hyper or ones for forged.
Old 11-29-2011, 09:25 PM
mycool240's Avatar
these are stock pistons... not gonna see nitrous often, but it will be used. i have not checked bore after hone but i will.
Old 11-29-2011, 10:27 PM
A.R. Shale Targa's Avatar
These are the things to consider......
The machine shop that honed the block doesn't care what your doing for rings
and their gaps. They are only concerned with straightening out the bore
(minimizing taper from top to bottom) and establishing cross hatch.
The .025/.027 gaps are a tad wide but not at all rediculous.
Saying it may see 150 later can and often always turns into 250. Trust me I
know juice and if a little is good....more is better.....
Those gaps will work fine for you.
Old 11-30-2011, 09:34 AM
mycool240's Avatar
ok... what about the oil ring, whats the spec on it? i searched but havent been able to find the max gap... im at .025 now.
Old 11-30-2011, 09:44 AM
KCS
Moderator
KCS's Avatar
That's more than enough. I was told by one of the big ring manufacturers that .011" is about the tightest you would want on the oil rings, but .025" will be just fine. There isn't much heat that far down the piston.
Old 11-30-2011, 10:30 AM
farmington's Avatar
hyper pistons retain more heat at the top of the piston, hence they recommend wider gaps than a forged piston.
Old 11-30-2011, 12:41 PM
mycool240's Avatar
ok so everyone agree that this thing will live fine with this ring gaps right? if so im gonna go ahead with the build
Old 11-30-2011, 10:34 PM
Give er'.....
Old 12-01-2011, 03:10 PM
ls1fst98's Avatar
i would say to get a good set of file fits and start with that, especially with a new hone and what not. but thats just me. if everyone else disagrees then go for it
Quick Reply: ls1 ring gap for 150 shot
