Signs and symptoms of worn motor mounts.
From my experience on my old '69 Z28 you can just start the car with the hood open and nail the gas a few good times. If the mounts are good there should be minimal movement. I had one separate on my '69 and it was very noticable. It looked like the motor was trying to jump out of the engine bay or try to roll onto its side. You could also here it cluck when it moved. Hope this helps.
STF veteran / 10 second club
Originally Posted by PCG
My shifter moves around a little bit when I start the car...could this mean that I need new motor mounts?
If you have a broken engine mount, it is very noticable. Just do what the other people said, open the hood, grab the throttle linkage on the throttle body, slam it some gas, and watch the engine. If the engine looks as though it is moving an absurd amount (or even trying to jump out of the car), check your mounts.
