600RWHP doable on this setup?
Old 12-06-2011, 04:40 PM
DavidPHumes's Avatar
Default 600RWHP doable on this setup?
Just wondering if 600RWHP is doable...
E85
5.3L L33 (so 9.9:1 compression)
LS6 intake
LS6 cam
80lb injectors
MLS head gaskets
ARP head bolts and rod bolts
Patriot Gold dual valve springs
Turbonetics TC76 .96 A/R turbo
24x12x3 FMIC
No accessories other than water pump and alternator
8.8" solid rear axle
Powerglide
I'm thinking 10-14lbs of boost. Probably 14
Old 12-06-2011, 04:52 PM
Ryans99ls1's Avatar
youll see 600.
Old 12-06-2011, 05:04 PM
tomz28's Avatar
Easy but 14psi for sure
Old 12-06-2011, 05:09 PM
Daniel0026's Avatar
I like the single turbo setup on a small cube engine. From personal experience, running the e85 with boost allows better timing and with a similar setup (small twins, not a single large on a 5.3) I was looking at 620-650 rwhp only at 8-10 psi. at 14 psi i would say pushing 650+ is definitely a possibility!
Old 12-06-2011, 05:10 PM
tta656's Avatar
pretty much the same build i have going on,,but a heavier car...nice...
Old 12-06-2011, 11:54 PM
skinnies's Avatar
About the same setup I had before, made 686rwhp on 18lbs thru a th400 and my big tires.
Old 12-07-2011, 07:23 AM
LS1NOVA's Avatar
I dont think you will have a problem hitting 600.
Skinnies:
How much did the billet 76 gain over the TC76 at the same boost levels?
Old 12-07-2011, 07:44 AM
skinnies's Avatar
Don't have a good back to back comparison as we changed other things, but 24lbs it made 855rwhp.
Old 12-07-2011, 08:58 AM
I see myself eventually moving to the Precision 76, but this should be awesome for now. If I could hit 650 that'd be awesome, but 600 is my goal. Thanks guys!
