Pontiac GTO 2004-2006 - cold air intake
gotjuice78
12-07-2011, 04:53 PM
well got my 2006 gto it came with a cold air intake otherwise its stock keep throwing lean bank codes tried cleaning the maf with no luck called a few shops and was told that I need to get a tune because the newer cars will do this anybody have the same issue just wanted to know.
Z2K_MrJ
12-07-2011, 05:34 PM
Possible you over sprayed or cleaned the MAFS ? They are very ez to fup
OVRPWRD
12-07-2011, 06:45 PM
Take it to AutoZone and they can read it for free. Then post up the code number(s) and see if someone can help.
Franchi
12-07-2011, 06:48 PM
I cant swear for the GTO's but I know that the 05 and up Mustangs, that's a common issue. Have to have a tune otherwise it will consistently throw a lean code out.
ULTIMATEORANGESS
12-07-2011, 06:52 PM
i threw no codes after my CAI install.
gotjuice78
12-07-2011, 07:22 PM
its throwing p0171 p0174 guys at speed inc and texas speed told me this would be an issue unless tuned and its a lingenfelter cai
ULTIMATEORANGESS
12-07-2011, 07:36 PM
i have an LPE CAI and had no codes.
svede1212
12-07-2011, 08:00 PM
There should not be any codes. Either the intake is improperly installed or the filter had too much oil and it got on the MAF sensor. The first thing to do is to check and make sure it's installed right and not leaking air somewhere and then get some MAF cleaner and carefully clean the MAF. The advise that you need a tune is wrong. The codes you're showing are that it's running lean which to me is saying you have a leak past the MAF.
gconnoyer
12-07-2011, 08:14 PM
check your manifold.
My buddy kevin had lean codes on both banks, and the bolts for his intake had loosened up.
Unlikely but it doesn't take anything to check.
gotjuice78
12-07-2011, 08:26 PM
I already cleaned at my buddies shop and cleared the codes it had six codes in it three of each then about five minutes later they came back I have read about the intake.By the way from the looks of it the last owner had headers on it from the look of the manifold bolts looking all new and the exhaust having new bolts. Also the clock switch is out with the steering wheel controls not working and the air bag light but I already know how to fix that. only thing that sucks about buying someones car is fixing all the stuff they didnt do right the first time
Death{AW}
12-07-2011, 08:56 PM
He might have done tune on it and somebody did not know what they do and they messed up your tune. Best choice would be bring it to tuner check your maps.
gotjuice78
12-08-2011, 07:14 PM
Intakes bolts were all loose about 1/2 to 1 1/4 full turns lets see if that had anything to do with what was going on if not just going to have to find somebody to help me anybody know someone in the area other then speed inc they are about 45 mins away i'm in zip code 60457 hickory hills il
svede1212
12-09-2011, 11:09 AM
Unfortunately you're 180 miles away or I'd be happy to scan it for you to see what's up and if the tune has been messed with. :( Hopefully someone around you has HP Tuners and can help you
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
