Pontiac Firebird 1967-2002 - will used instrument cluster read correct mileage???
2000SSMAN
12-09-2011, 03:20 AM
Hi,
One of my guages might be messed up in my instrument cluster and might have to get another cluster so i was wondering if i swapped them out if my car will my car still show the correct mileage and if not please explain if possible. All help is appreciated.
Paul Bell
12-09-2011, 07:24 AM
Negative. The accumulated recorded mileage is stored in the cluster electronics.
Sorry!
mrrman
12-09-2011, 08:18 AM
in my 87 TA, I moved over the mileage chip to the "new" digital panel and it worked...mine has the digital console however
2000SSMAN
12-09-2011, 12:16 PM
Is there any way to reprogram one...does a dealer have any access to anything like that...can the Guage be fixed?
Paul Bell
12-09-2011, 05:46 PM
I don't think it's legal to do so unless a dealer was replacing a cluster. They'd have to have the car in their possession for service. I doubt you'll find anybody to take your odometer and change the numbers.
2000SSMAN
12-10-2011, 01:16 AM
So if I got another cluster a dealership could fix it or would it have to be a brand new cluster that I have to buy through them? Btw. That blue ta looks really good
vrtch ss
12-10-2011, 01:31 AM
The dealer will sell you one and require your old cluster in exchange as they rebuild them and resell them. Also they will program it to your current mileage.
Paul Bell
12-10-2011, 06:28 AM
This is the company GM uses to service gauge stuff:
http://www.modelelectronics.com/index.asp
Question. Will the car be branded as TMU or odometer descrepacy on Carfax or the title?
Paul Bell
12-30-2011, 06:32 AM
What is "TMU"?
What is "TMU"?
TMU=True Mileage Unknown. A lot of states brand the title as such if there is a odometer issue which affects the value. Kind of like Flood, Salvage, etc..
TMU=True Mileage Unknown. A lot of states brand the title as such if there is a odemteter issue which affects the value. Kind of like Flood, Salvage, etc..
FL does a mileage exempt if the car is 10+ years old.
PA does that too, not sure if it's 10 or 20 years old. Mileage exempt and TMU are two different things. Mileage exempt can be from age, TMU means there was a problem with the miles reported.
idformula
01-02-2012, 01:01 PM
This is the only place that I know of
http://www.tacomaspeedometer.com/index/
Ah ok thanks for clearing that up. :-)
DrJele
01-05-2012, 01:34 AM
hi
i was having a similar problem and searching the web i found this site : www.correct-mileage.co.uk/.
they solved my problem.
hope it helps.
Paul Bell
01-05-2012, 07:21 AM
Welcome to LS1tech!
Here in The US, there are federal laws that pretty much prohibit odometer rollback.
http://www.rolledbackodometer.com/federal-odometer-law.html
the impaler
01-06-2012, 12:28 PM
Paul, your link seems to only cover odometer fraud, I'm not sure it would apply in this case, if the op is trying to set the correct milage.
Spartan7
01-06-2012, 08:53 PM
Some companies can roll the odometer forward for you, that's legal. Rolling it back is definitely illegal. You'd have to buy a new one from the dealer and have them set the correct mileage.
