Anyone got any dyno #'s for eldebrock new headers?
I was wondering if anyone has any #'s yet and how was the install? I dont know of i want to get the eldebrock uncoated or coated pacesetters.
Thats me. The car picked up that in the midrange NOT at peak. Power under the curve is more usable to me than peak HP. Looking forward to the NA track times to see if there is any increase there.
Mike
Mike
This header is going to shine more on a big H&C, stroker, or any motor with nos, than it will NA.
Mine is still hanging on the wall, waiting for testing to be completed with the current setup. When I decide to install, I will post up before and after dyno, and also track times.
Mike
Mike
How did the install go? Did the hammer or torch have to be used?
Any ground clearance issues?
Is a Y-pipe available for it?
Mike
Originally Posted by smokemup
What does your car have for mods, displacement?
Mike
Hey Mike,
Thanks for the info on the Edelbrocks! Do you have any pics of the ground clearance and/or fitment? I have the Eibach Pro Kit, and I am concerned about clearance. Do you happen to have overlays of your two dyno sheets to show where the gains were?
Thanks!
Thanks!
I disagree strongly. I have STOCK heads, 227/234 579/581 116 LSA cam and it picked up tremendously in the midrange. That is the power that I use. Yes i lost a few down low (3200 and less) but my stall leaves off the brake at 4200. The ground clearance would be an issue on some cars. Its not only for the H/C, stroker, or NOS motors, its for everyone looking to get that extra edge. If the car has the potential to make more than 450rwhp than Id suggest them. For a bolt-on car, I cant justify that yet. My car is cam only currently and it gained alot where i wanted it. Even gained about 5-6 up top hp and torque.
Mike
Mike
I personally like the 3.5" merge collector. I got a feeling the NOS is gonna like that one. I can only hope to see gains as good as the ones that you saw. Thanks for sharing the results
