F-Body Oil Pan, LS1 Waterpump, ARP Bolts, LS2 Timing Chain, 8.8 Rearend
Needing these parts for a build.
F-body oil pan, need it all, pan, pickup, stick and tube.
LS1 water pump, only want new or slightly used!!
ARP rod bolts for 02 LQ4, again new or slightly used!!
LS2 timing chain. New or slightly used
8.8 Rear end from Mustang Foxbody. Only need the housing, brakes, and bearing caps. Need local to east Texas also.
thanks!
thanks!
I have an LS1 oil pan from an f-body with pickup/windage tray for $200. I also have an 8.8 setup for a f-body with a mini ladder bar setup (not sure if youd be interested in that at all?)
Do you both of you guys with the pans have the pan, pickup, windage crap AND the stick/tube?
Mike will be in touch on those rod bolts, sounds pretty cheap!
Not interested in the 30K mile timing chain. thanks
Gonna let it ride for a couple more days and see if possibly I can find someone with the Fbody pan anda water pump both. Keep it coming!
