push rod length?
Old 12-20-2011, 02:53 PM
devin.918's Avatar
LS1Tech 10 Year
Default push rod length?
Hey guys im doing h&c after chritsmas im goin with a basic tsp 224r (because its a dd) and stock 243 non milled heads and im goin with .045 head gasket any idea on push rod length? I am getting a push rod length checker but it would be nice to get it right when i order the stuff. my car is a 2000 ss
Old 12-20-2011, 10:20 PM
Paul57's Avatar
7.4 is a fairly good place to start and seems quite common after a cam change. Be sure to follow the instructions in post #3 for best results... https://ls1tech.com/forums/generatio...s-too-big.html
Old 12-21-2011, 10:19 AM
PREDATOR-Z's Avatar
Measure, I would change the lifters while you are in there and then MEASURE
Old 12-22-2011, 11:33 AM
devin.918's Avatar
LS1Tech 10 Year
o yea forgot that im going with ls7 lifters, thanks guys, like i said i just would love to get it right the first time
Old 12-22-2011, 11:44 AM
smokeshow72's Avatar
How many miles on the engine? I don't think a lifter change is necessarily warranted if you have 50K on the clock; that isn't a tremendous camshaft.
If you haven't ordered it yet, did you consider the 228R? I love that thing.
C
Old 12-22-2011, 01:00 PM
ZeeOSix's Avatar
If you use a pushrod length checker tool correctly, you will know exactly the length you'll need for your setup. You have too many changes to the stock setup to "guess" at a length. Measuring is the only sure way in your case.
Old 12-24-2011, 12:09 PM
2002TransAmKid09's Avatar
DEFINITELY go with LS7 lifters!! the LS1 lifters are KNOW for collapsing, happened to me, you can hear it knocking in my old vids. the LS7s are perfect. they should just post a list on any stock TA before they come out to watch for.. the 10 bolt rear, and the lifters should be #1 fix
Old 12-25-2011, 11:16 AM
devin.918's Avatar
LS1Tech 10 Year
its got 88k on it, no i havent ordered it yet but i just wanted to stick with a smaller one because its my main dd. ok thanks ls7 lifters were one 120 bucks so i figured why not
Old 12-26-2011, 09:14 AM
crainholio's Avatar
There's a saying...MEASURE once, cut twice; MEASURE twice, cut once. Words to live by with LS valvetrains.
Old 12-26-2011, 11:01 AM
SSTYCOON's Avatar
Ls7 lifters are the ideal choice. Most likely 7.400” however the LS7 lifters like a little more preload
