dont know where to post....5.3 vs ls1
will the drive accesories off a 5,3 work on an ls1? i want to run the ls1 intake and water pump. all i need drive wise is crank pulley,power steering, alternator. please help asap....
here are some pics
here you can see where we cut the idler off beside the alternator
here you can see that the idler is now below the alt pulley
***EDIT*** the spacer was perfect but the bolt was too long, i'm not sure if they just sent me the wrong bolt or what but either way it didn't work
I just saw this on a thread by -TheBandit- and decided I'd order the same for my conversion
From Misumi USA (www.misumiusa.com), the spacer is PN KNCLM10-30-20 and cost $5.70. It is nickel plated steel, 10mm ID, 30MM OD and 20MM length. The bolt is PN CB10-160 and cost $2.40. It is M10x160mm length. Total $8.10.
here are some pics
