Brand new Big Block Chevy 496 stroker.
Category: Engine - Complete Motors
Price: $6000
Location (State): IL
Item Condition: Brand New
Engine: Big Block
LS Engine?: Fits LS Engine
427 punched out to a 496 stroker.
Internally balanced
Bore 4.310
Stroke 4.250
New Scat Steel Crank
New Manley H Beam Rods
New SRP Pistons
New JE Rings
New Clevite bearings
New Chromoly Push Rods
New Springs
New Valves
New retainers
New Locks
New Keepers
New Valve seals
New Comp Cams Hydraulic roller lifters
New Comp cams Hydraulic roller cam Lift 612 Duration 314 on a Lobe of 110.
Chevy Oval port heads. 2.06 Intake 1.72 Exhaust
Canted degree angle.
Competition valve job.
New Timing chain
New Oil Pump
New Freeze Plugs
New Edelbrock RPM Air gap Dual Plane Intake
850 Demon carb
New March Pullies
New flex fan
New Edelbrock Mechanical Fuel Pump
New MSDdistributor
New water pump
New Moroso Plug wires
Air cleaner with new filter
New Alternator converted to one wire
New Thermostat housing and T stat.
New Valve cover breathers
Comes with Aluminum Overflow catch can
New High Torque stater
New Solid Motor mounts
New custom Aluminum Valve covers
The motor was thoroughly checked, hot tanked,pressure tested, bored, notched, line honed and assembled.
The motor dynoed on 518 HP and 541 TQ. Have the dyno sheet. The motor has the capabilities for 650HP with Aluminum heads naturally aspirated. It will also handle Nitrous.
The motor is together and has 540 miles on it since it was put together. Its ready from carb to oil pan ready to drop in. The only thing needed is either a flexplate or flywheel, spark plugs and your headers.
The motor cost $6,656 to build in just parts and machining. This doesnt include all the add ons of the engine. That was only the price of the long block. I have over 8 Grand in the entire setup.
I have all the reciepts for the motor build, nothing was spared. $6,000 OBO NO TRADES.
If Interested call Mike at 847-489-1982
