Nitrous window switch
#1 what are you guys running to turn on and off your nitrous systems ?WOT switch wired into my MSD Window switch
#2 where do you have it mounted? pics help a bunch passenger side shock tower, click the link in my sig for pictures
#3 how hard was it to wire up pretty self explanatory with the instructions
its 390 on motor... not on the spray ....
I think I remember reading that article... nice looking car...like a 250 shot? I think?
anyways
Holley EFI Controls Everything.... Main Switch Arms the System, 1 stage and 2nd stage have their own window switch settings completely independent of one another if desired
Custom Switch Panel/Gauge plate in the Center Console section where the Radio and HVAC are normally at
My Whole Car is a Custom Wiring Job....you wouldnt know it from just looking at it.
For me its as simple as one wire to arm the Nitrous System, One wire to turn on stage 1, one wire to turn on stage 2
both stages independent...Hard hit off the line, progressive 2nd stage...run only progressive 2nd on the street so as not to just blow off the tires
When the 2 step is on it disables the Nitrous so I'm not spraying while sitting at the lights
and honestly.. it was really simple to wire and set up..
and I know this isnt exactly what you meant...but I'm just showing it is an option
