So I'm getting some 799 heads and I have some questions.
So I'm getting some 799's tonight probably get them resurfaced and valve job and back cut. Another question or questions, how much should be milled and where what do I have to do to get the coils working for these heads being that they are going on my 1998 ls1 camaro or do I have buy new valve covers? Or is there a conversion kit? Ideas anyone?
Will I be able to use my TSP 7.4 pushrods off of my stock ls1 heads, or am I going to have to buy new ones as well. Also even if I buy centerbolt valve covers don't I some kind of bracket to hold coils?
Youll have to measure for proper pushrod length in any situation where you make changes. Although the 7.400" will work, they just might not be optimal. Ive run 7.400s blindly in many many dyno sessions and never had a problem. But its different when its your personal vehicle....
I think youll need coil brackets as well, you might even need the coils and coil brackets. I never mess with perimeter valve covers.
You will need: center bolt valve covers, coils, brackets, harnesses (coils/brackets/harnesses should come together for ~$40 per side from salvage, maybe less). Truck coils will work. Just ask for a pair of coil packs for a 2000+ GM V8 (I exclude 99 when I ask because some systems only show 99 as a vortec 350, not a 5.3 liter).
EDIT: If you use the truck coils you will need to bend the fuel rail inlet, this can be done easily by slipping a socket over it and go slow. Only needs to move like 1/8-1.4"
IMO if you aren't going to get them ported at least try to get some sandpaper rolls and clean up the casting flash and the lip near the intake valve seats.
Mine were absolutely terrible as cast. There were dime sized areas where **** was protruding into the flow path from the port walls and a fairly large step near the seats.
I had mine milled .010"
Throttle response and torque are significantly improved over the stock heads and my old smaller cam. I expected to lose some bottom end with the new larger cam but was delighted to have gained so much.
If I hadn't been getting into the area of having to check PTV clearance I would have milled more.
