My first upgrade?
Old 12-28-2011, 03:11 PM
wurnstrum's Avatar
Default My first upgrade?
Hello everyone, I have a 2000 Trans Am WS6 which is completely stock except for the catback, what would be the best thing to do first? Get a tuner? Headers? Lid? Or what? Any help is greatly appreciated. Thanks Aaron.
Old 12-28-2011, 03:34 PM
LS-ONE_DAY's Avatar
Lid is the cheapest. There is no real wrong way to start as far as bolt ons. Lid, headers and y-pipe, suspension mods would all be good places to start. My car came with a catback as well and I did an SLP lid, ARH headers and y-pipe, poly motor mounts, and I have lower control arms to install and I think subframe connectors will be next. If you have an Automatic also consider a higher stall torque converter (tranny cooler is a must with that) or a good set of tires
Old 12-28-2011, 03:47 PM
wurnstrum's Avatar
Sorry, I forgot to put that, yes it is an automatic. Thanks for the info. What about a tuner/programmer?
Old 12-28-2011, 04:05 PM
LS-ONE_DAY's Avatar
Not really worth it. Taking the car or sending the PCM out for a mail tune will provide a lot more functionality for changes than a handheld programmer will give you. For mail tunes I suggest Frost (www.tunedbyfrost.com) which are $150 (a lot cheaper than a programmer) or full dyno tunes find a reputable shop near you or look up a sponsor on here in your area that can help out.
Old 12-28-2011, 04:57 PM
ULTIMATEORANGESS's Avatar
Smile
stall. get a quality one. youll be impressed.
astro11271984's Avatar
p&p throttle body and lid if ur on a budget
Old 12-28-2011, 06:08 PM
sreve's Avatar
What he said........... and adjust the shift points
Old 12-28-2011, 06:10 PM
LS-ONE_DAY's Avatar
Actually I just thought of a question for mod order. I just installed my longtube headers...are those going to have to be removed in order to change the converter when I buy mine in the Summer/Fall?
Old 12-28-2011, 06:39 PM
zracer323's Avatar
Nope, you have to drop the y-pipe but the headers stay in place.
To the OP: I would do a convertor first, then headers, ORY and lid.
Old 12-28-2011, 07:03 PM
LS-ONE_DAY's Avatar
OP, keep in mind with a converter you WILL need a tranny cooler...and you'll need new tires also
Old 12-28-2011, 08:05 PM
MikeWS6's Avatar
Lid and then pick up some long tubes.
Old 12-28-2011, 08:42 PM
TransAmWS.6's Avatar
O/R Y + LT's is what I would do next. I'd save the Lid for a little later on, it just doesn't really do enough to make it a "must have" item, that's just my opinion though, many may feel different.
Old 12-28-2011, 08:58 PM
beyonddisturbed's Avatar
lid will be cheapest. i would go with headers + y then lcas and lca relocation.
Old 12-28-2011, 09:15 PM
wav3form's Avatar
No way the lid is like a rite of passage! It must be done first!
Old 12-28-2011, 09:44 PM
Omega Doom's Avatar
do at least the 3500-3600 stall with the TUNE and you will be kickin' *** and love it! throw on some juice and it would be a blast!
Old 12-28-2011, 10:23 PM
wurnstrum's Avatar
Wow, thanks for all the responses. But I do have another question, everyone keeps talking about a y-pipe, I thought that an x-pipe was better. So which is the way to go?
Old 12-28-2011, 10:26 PM
Cheap Guy's Avatar
Shocks - something that will make a difference at any speed.
Old 12-28-2011, 10:50 PM
VandykeT/A's Avatar
X pipes are for true dual set ups. Our cars have single exhaust so it uses a Y. You can put true duals on your car but for stock internals your not going to notice a difference other than sound. I would do the free mods with a stall and a tune. Then shocks, lid, longtubes, and ory.
Old 12-28-2011, 11:00 PM
wurnstrum's Avatar
Oh ok, so doesn't my car have a y-pipe now? If so what is the upgrade to the y-pipe?
Old 12-28-2011, 11:10 PM
LS-ONE_DAY's Avatar
yes cars have a y-pipe stock, but a new y-pipe will be larger diameter, better material, and a lot better flowing.
