valve train noise
it won't be the intake as i've got individual throttle bodys i've just been out in the car again as soon as it gets hot you can hear the top end
i think i'am going to pull the oil pump back out and check it
right before i start pulling the engine apart again my cam is a esp 236/242 111lsa when worm it sounds like a sewing machine it has double row springs and ls7 lifters the oil light takes 2-3 secounds to go out when starting up hot or cold
would you being checking the oil pump or is it normal with this size cam?
I got a comp 224/230 with comp 918 springs and comp 7.4 pushrods and when listening real hard under the hood I got "sewing machine" noise too. I just attribute it to the comp xer lobes with fast ramp, I agree if you get a custom cam or something like an eps cam would quiet the valve train noise down.
