Help Me Make It 10 Sec Et
Old 03-16-2004, 08:57 AM
Z28 10 SECOND CLUB's Avatar
Default About To Spend 12k Help Me
hey every one i need some advice/info on making my 1999 Z28 run 10's.
here is a list of what i currently have:
whisper ram air kit
whisper air lid
granatelli mas air flow sensor for nitrous
ls6 intake manifold
msd plug wires
ngk plugs
tci +1500 stall torque converter
bmr strut tower brace
Finish Line Performance long tube headers
cats removed
borla cat back exhaust sytem
3.73:1 strange gear
bmr subframe connectors
bmr lower controll arms
NOS dry kit 125 shot hooked up to the ram air underneeth air lid
mickey thompson et streets 26x10.5-16
im currently running 12.19 E.T.(fastest time) on motor with a 1.65 60' and
11.59 E.T. (fastest time) on nos with a 1.59 60' im about to add the following parts:
BILLINGSLEY RACING HEAVY DUTY ANTI ROLL BAR KIT FOR REAR: 399.99
BMR TUBULAR K-MEMBER: 439.99
SET OF UPPER AND LOWER A ARMS: 549.99
SET OF QA1-HAL SHOCK AND SPRINGS: 689.99
SPOHN CHROME OLY TORQUE ARM: 530.00
TNT WET KIT CONVERSION 125HP: 399.99
STRANGE 12 BOLT REAR END WITH 4.11:1 GEAR: 2299.99
MEZIERE ELECTRIC WATER PUMP: 569.99
FINISH LINE PERFORMANCE STAGE 4 TRANS MISSION: 1999.99
VIGILANTE TORQUE CONVERTER 3600 STALL: 699.99
ACCEL 48LB/HR INJECTORS: 479.99
FUEL PUMP UNCERTAIN WHICH ONE TO GET AT THIS POINT
SNEEKYPETE NOS SYSTEM: 219.99
WELD PROSTAR WHEELS 15X8 (5.5INCH BACKSPACE): 320.00
MICKEY THOMPSON ET DRAG SLICKS 28X10.5-15: 340.00
FRONT SWAY BAR REMOVED
THROTTEL BODY SWITCH FOR NOS: 29.99
MSD RPM ACTIVATED SWITCH: 76.95
****sorry for all the caps cut and paste job********
will all the suspension work and everything else i listed put me into the tens? i am trying to make a 10 sec camaro with no internal engine work cause i have never heard of anyone doing it. suggestions on parts to or not to get would be apprieciated. as well as if you know where to get these parts cheaper. thank you for you input and help.
Old 03-16-2004, 10:15 AM
Motorboater
SilverGhost's Avatar
1) 10 sec with no internals was done a long time ago, by the guy who did my custom paint, he ran 10.80 here in chicago i'd say about 4 years ago now.
2) What size exactly is that stall, will it handle the spray? you hit it too hard and it could balloon past your rev limiter.
3) You will want a 15X10 Prostar for the back, not 15X8 if you are going to run 28X10.5 et drags..the tire will not fit properly on a 15X8, it will look like a marshmellow suck on a wagon wheel, it'll fit but won't work properly, have much less contact patch on the ground.
4) the car will need to be tuned when you add those injectors, you can't just stick em in and go racing, youre fuel system will make the car run really pig rich. if you are going to run a wet kit only they are not necessary, certainly not ones that big. I ran 200 shot wet all day long a few years ago on stock 98 injectors, i know yours are smaller, but 48 lb'ers are not necessary.
those are just some quick observations from your info..
Old 03-16-2004, 10:44 AM
Julian's Avatar
doesn't nitrous love headers?
Old 03-16-2004, 07:54 PM
beardWS6's Avatar
Check Sig! I get there all the time!
Old 03-16-2004, 08:06 PM
my question was to every one was with the parts i have and what im about to purchase is mid 10's a dream or very possible. i dont want to buy heads or a cam. knowlageable answers and opions only please
Old 03-16-2004, 08:32 PM
eviltwins's Avatar
Why waste your money on a sneeky pete kit, it's worth like 35 horsepower, tops. I say sell your NOS dry kit, get a NX dual stage kit, and giver all she's worth!
Old 03-16-2004, 08:54 PM
Restricted User
CAT3's Avatar
If your running a 125 shot and only getting .6 something is not right. Ditch the Dry kit, get an NX MAF kit, Walbro 340M intank pump, that should get you there with a 150 shot, or a 175. If not, get the TA, Wheels and Tires, and so on.
Old 03-16-2004, 10:09 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
FLP stage four trans tci converter g5x2 cam and a tune you should be good to go. for a lot less money than your list.
Old 04-04-2004, 07:46 PM
Dr.LS1's Avatar
Why don't you just get a new cam. You can get a nice package for cheap. Something around 230 or so duration. That would drop you ET considerably for a good price.
Old 04-04-2004, 08:35 PM
koolrayz's Avatar
The fastest stock internals in the nitrous list is 10.81 by hacker joe. I have many new mod's and expect to be in the 10's with stock internals this spring if it ever stops raining so the tracks in Ohio can open
Old 04-04-2004, 09:53 PM
redsscamaroboy's Avatar
10's on spray with stock internals is not too hard.
1 guy in my car club ran 10.8x@124 with Long tube headers,ORY,Flowmaster cat back(if you can believe that) and a Nitrous convertor(PYE3400).99 SS A4.
Pulled 1.4 60fts and did it all on a 175 wet kit (NX).
He did not upgrade the fuel pump and ended up burning up a valve,but only after running that way for over 1.5 years .
All on E/T streets with skinnies up frt.
Your list of parts is long and too much money.
Get a good fuel pump,NX wet kit and DO NOT USE a VIG3600 for a big shot of nitrous.
I did a 150 rwhp shot for over a year on that convertor and it stalled around 5200 on the bottle. Get a nitrous convertor and get a good one too.
With traction and the mods you have you could get there.
Good luck
Dave
Old 04-04-2004, 10:40 PM
Fiery Features Director
Zangel's Avatar
Why are you doing all of this now? I thought you were having a 427 ci C5R stroker motor installed at the end of May? Are you still going to go through with your plans of running 8's or did you change your mind?
Good luck with whatever you do!
Old 04-05-2004, 09:46 AM
PREDATOR-Z's Avatar
5177 125rwhp shot. See my time. No headers + stock internals.
Old 04-06-2004, 01:14 PM
Strahley's Avatar
Why do you NOT want to get new heads/cam? Doing that will drop your ETs a lot. That on top of having stock headers, it's going to be tough. Best of luck though
Old 04-06-2004, 05:37 PM
SDB
SDB's Avatar
why do you ask...your name already says your running 10's!!!!!
putting the cart before the horse, eh?
SDB
