Whats the deal with the lxl lobes?
Old 01-03-2012, 01:01 PM
Cosmos's Avatar
Default Whats the deal with the lxl lobes?
While Ive been playing around with cam ideas, Ive been thinking about using these lobes. I know Patrick G uses them on the exhaust side but what about the intake side? They almost look like the EPS lobes but I cant find any info on them even on Comps website. Anybody know what the deal is?
Old 01-03-2012, 05:12 PM
1999BlueTA's Avatar
Good question, im wanting some info on these lobes also.
Old 01-03-2012, 05:23 PM
Cosmos's Avatar
Ill call them tomorrow and see what they say.
Old 01-03-2012, 07:22 PM
Fry_'s Avatar
I do believe they are designed as exhaust lobes that set the valves down softer to reduce valvetrain noise and are more often than not used with LSL intake lobes.
Old 01-03-2012, 08:54 PM
SweetS10V8's Avatar
I'll save you some time......
The LXL series is based off the popular LSL profiles but are optimized with lower acceleration and a softer closing ramp for less valve train noise and better stability with higher (1.8:1+) ratio rocker arms. These profiles are an excellent choice on the exhaust when used with an LSL intake and perform well for both the intake and exhaust when used in either LS7 or other high ratio applications. These also are a great choice for road race type engines that require extended use at high engine speeds.
Old 01-04-2012, 08:52 AM
LS1 Tech Administrator
Patrick G's Avatar
I use the LXL lobes on the intake side on some endurance and forced induction applications where enhanced valve control is required.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 01-04-2012, 09:00 AM
bww3588's Avatar
would/could these lobes used on a solid roller cam to help keep valve lash in check longer to prolong adjustments? Main reason I ask is because I plan on going solid roller for my 370 build. I understand the dynamics and maintenance issues related to a solid roller cam, and know they require lash adjustments, however the only ones I have experience with are old SBC solid rollers that require lash adjustments very often.
I know it will require lashing, not trying to escape that at all, just the frequency. I also understand that after a trip to the drag strip, lifting the valve covers will be a must regardless. I am just trying to avoid that check/adjustment after a weekend cruise.
Old 01-18-2012, 06:52 PM
PhxTriode's Avatar
I have one of Pats LXL/LXL cams in my 09 CTSV with mild lift and duration, valvetrain is nice and quite. 728rwhp @ 6400rpm and over 600ftlbs from 2800-6200rpm with 19mpg in a 4400lb car. stock 6.2l with cam, headers and a 2.9l whipple at 15.5-16psi.
Needless to say a great lobe profile and gets the job done in a caddy
Old 01-19-2012, 12:06 AM
bww3588's Avatar
Old 01-19-2012, 03:30 PM
yonerhottlt1's Avatar
So these lobes have no advantage when using 1.7 ratio rockers?! Besides the quiet valvetrain?!
Old 01-20-2012, 09:06 PM
Anybody...?!
Old 01-24-2012, 06:57 AM
SweetS10V8's Avatar
And added valtrain stability, which can lead to longer life as well.
Old 01-30-2012, 06:04 PM
Oh ok...good deal
Old 02-01-2012, 05:34 PM
JS01's Avatar
FWIW I'm doubtful that these could be used with a solid lifter/rocker for any length of time due to being a hydraulic lifter lobe. Solid roller cams incorporate a "lash ramp" into the lobe profile and being a hyd. lobe I would doubt it opens soft enough to not beat things up on a SR application. I would consult an engineer at Comp to verify this though.
Alot of times you can use a solid roller lobe on a hydraulic lifter setup but not vise-versa I'd imagine. If you are looking for a stable/smooth solid roller lobe I'd take a look at the RZ series.
Old 10-23-2012, 11:34 PM
hiltsy855's Avatar
Anybody know where to find lobe specs for LXL? Specifically duration numbers @ .006" and .200" lift? I don't see anything in the 2012 catalog.
Old 10-24-2012, 09:53 AM
Sales@Tick's Avatar
Originally Posted by hiltsy855
anybody know where to find lobe specs for lxl? Specifically duration numbers @ .006" and .200" lift? I don't see anything in the 2012 catalog.
266 214 136 .350 .053 .042 .560 .595 .630
270 218 139 .352 .059 .047 .563 .598 .634
274 222 143 .354 .065 .053 .566 .602 .637
278 226 147 .356 .072 .059 .570 .605 .641
282 230 151 .358 .079 .065 .573 .609 .644
286 234 155 .360 .086 .072 .576 .612 .648
290 238 159 .362 .094 .079 .579 .615 .652
294 242 162 .362 .101 .086 .579 .615 .652
298 246 166 .362 .109 .093 .579 .615 .652
Old 10-24-2012, 12:08 PM
hiltsy855's Avatar
Thanks Martin.
Old 10-24-2012, 04:08 PM
Sales@Tick's Avatar
Thanks Martin.
No problem.
Now, you sure you know what you're doing with all those numbers....?
Old 10-31-2012, 05:52 PM
hiltsy855's Avatar
Originally Posted by Martin@Tick
No problem.
Well Martin, they are just numbers so I can't really hurt myself can I? LOL. Here's the comparison I wanted to make between my current EPS lobe and an LXL lobe with the same duration @ .050" lift:
EPS 230 duration @.006"-279, @.050"-230, @.200"-151
LXL 230 duration @.006"-282, @.050"-230, @.200"-151
Since the .050" and .200" durations are identical (and the max. lift numbers are close) it stands to reason the performance characteristics of the two profiles would be similar. I know plotting 5 points of a cam profile doesn't tell the whole story but it gives me a ballpark view. Clearly the additional duration @.006" on the LXL helps the valve on & off the seat easy.
Old 11-01-2012, 03:50 PM
Sales@Tick's Avatar
Hey you do know something!
You are correct, the longer seat timing of the LXL is telling us in this case that it is slower off the seat than the LSG lobes are. The shorter seat timing on the LSG lobes tells us in this case that they are faster off the seat than the LXL lobes are.
Quick Reply: Whats the deal with the lxl lobes?
