Transition from efi to single plane set-up
Old 01-05-2012, 07:14 PM
silverstreak98maro's Avatar
Default Transition from efi to single plane set-up
H/c/i ls1 motor made 440/405 to tires with ory n catback, was wondering what kind of gains to expect from ls6 ported intake and tb set-up to single plane set-up is it worth it
Old 01-05-2012, 07:35 PM
Blk98Vert's Avatar
It's not that simple, unless you are mostly racing don't get one
Old 01-05-2012, 07:38 PM
thanks for input bro
Old 01-05-2012, 09:26 PM
outkast6991's Avatar
Need more details of your intended single plane setup to give you an opinion. Also if you do switch a cam change is necessary for strong results
Old 01-07-2012, 04:25 AM
MikeFSKSpeed's Avatar
Would you be looking to do a 4150 TB or an elbow with an LS style?
Old 01-07-2012, 07:42 AM
SweetS10V8's Avatar
EXACTLY!!!!
Drag race only, big cam, high rpm? = Single Plane
Street/Strip = Plastic manifold, LS6/FAST
Old 01-08-2012, 07:06 PM
a-low's Avatar
Maybe someone that's running one on street car can chime in. Personaly i think if someone is running
a big stall/cam you wont feel the loss of torque anyway.
Old 01-08-2012, 07:42 PM
tripblackls1's Avatar
Coming from a person that has owned a single Plain intake street car , I do not recommend it , and if you do you need to run a 4hole tb
I went from ls6 to vic Jr with low pro elbow and lost power everywhere
I am now using a proflo w/ boost and love it
Old 01-09-2012, 07:38 AM
very nice and thanks for infoya its more of a street car occasionally to the local track
Quick Reply: Transition from efi to single plane set-up
