Tons of F Body Parts!!!! (93-02)
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IN
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
**So check back from time to time, as I may have something you need.
**And feel free to ask if you need something specific.
First List of parts... (1-8-2012)
- Red Drivers Side Camaro Door 93-02 (The Shell Only) $50 (w/o mirror)
- 93-02 Drivers Side Camaro Door Mirror $50
- LS1 AIR Injection Kit $40
- Set of T Tops from an 01 camaro (Non Dot Matrix) $150 pair
- 98-02 Trans Am Headlight Assemblies (Pewter, Work Great) $400
- LS1 GTO Water Pump $40 (Unknown Condition, bought it used and was told it worked great)
- LS1 Stock Spark Plug Wires $15 set
- 2 Factory LS1 Y Pipes $40 each
- 99-02 Plastic gas Tank $100
- 99-02 V6 Fuel Pump Assembly $50
- LT1 Engine Mount Stands $30
- LS1 Cooling Bypass Tubes(Goes Under Intake Manifold) 3 Available $35 each
- 10 Bolt Rearend gasket $15 shipped? If your local and need it $5
- 4l60e Transmission Pan Gasket $15 shipped? $5 local
- I have 1 LS1 Stock K member left. $75
- Complete Valve Seals. 8 intake and 8 exhaust seals. Bought them for my LS6 Heads a while back, and never used them. "NEW", still in the packages. Will fit standard LS1 Heads as well. They are IDENTICAL. $40
- LS2 CORVETTE Fuel Rail Covers $100
- Powder Coated (Annodized Red) LS1 Valve Covers and Timing Cover $175
- LS Truck Oil Pan with pick up tube $50
Added more parts... 1-8-2012
- 1 98 Ls1 Trans Am Passenger Side Air Bag, 1 99 Trans Am LS1 Passenger Side Airbag, And 1 98 LS1 Camaro Air bag... $100 each
- LT1 Starter $30
- 93-02 F Body Trans. Tunnel Braces (3)Stock Braces $15 @, 1 Custom $30
- 01 V6 Camaro Dash Cluster "Instrument Panel" $50
- E. Brake Assembly from my 99 TA With Cable and Bracket. $50
- Solid Transmission Mount $25
- Misc. Trq. Arm Mounts/Brackets $25 each
- Misc Exhaust Hanger/Trans. Bracket. 1 a4 & 1 m6 setup. $25 each
***A4 hanger is Sold / M6 Is Pending!***
- Engine Mount Heat Shields (On drivers side engine mount) 3 avail. $10 each
- Rearend Shield (Bolts onto the top of the factory 10 bolt rearend) $10
- 98 LS1 F Body Water pump Pulley with Bolts. $20
More Parts... 1-9-2012
- Full set of MSD LS1 Engine Coils $400 for the set of 8.
- Jet Performance Module for a 98 LS1 F Body $200
- Stock 10 Bolt with 2.73 Gears (Minus Brakes) Perfect Condition $300
- Full HVAC Box (Includes Blower Motor, Heater Core, Resistor, AC Condensor, Etc. All of it is there) from a 98 Trans Am $200
More Parts 1-10-2012
- Delco Amplifier (Out of an 02 Camaro) $35
- Fuse Box Cover (Drivers side of dash, on inside of car) $10
- GM Alarm Shock Sensor (Spare tire area - in rear, on passenger side) $20
- Coin Holder (In center console) $10
- (Grey Handle), E Brake Assembly w/o cable $20
- LT1 Coolant Hose
- Under Dash Plastics $20 each or $30 for both
- Door Sill Plates "Ebony" (The parts you step on when entering the car) I have both Sides $20 each or $30 for both
- Both front "A Pillar" Panels. (Runs from the T Tops down to the dash itself) *People mount their gauges to these* I'm asking $20 each or both for $30
- 3 Exhaust Heat Shields for f Body's (Passenger side floorboard, They keep heat off the floor) I'm asking $15 each
- 1995-2002 3.8L Trans. To Engine Brackets (Both Sides) Off 02' Camaro $40
1-18-2012
- Complete 6.0L Truck Intake setup $100 (Intake, TB, Fuel Rails, Sensors, Injectors, etc.)
- Complete 6.0L Engine Accessories and brackets... $150 (Power steering pump, water pump, belt tensioner, ac bracket and tensioner, NO ALTERNATOR, AC COMPRESSOR, OR STARTER though!)
- LIKE NEW Set of 918 Comp Beehive Valvesprings $150 shipped
*** 2-17-12 ***
ALSO.... I Have 2 LS1 Longblock's for Sale. (No oil pans, accessories, intakes, etc. Complete longblock with all other covers included though.)
1 is an 02' LS1 and has 92k miles on it. Ran Great when pulled out! No Issues...
1 is an 01' LS1 and the mileage is not verified b/c I have never heard it run... I was told it ran and drove up til the car was parted out. I Pulled the drivetrain out of the car, and Yes the whole car is parted out. The guy I bought it from is a Member on here as well. If you have any questions, feel free to PM me. I am Asking $1500 OBO for each of the LS1's.
I will assure you that the 02' LS1 runs Great b/c I heard it run.
The 01' I will not! B/C I did not actually hear it run. But again, I was told it was good and I pulled it for the guy!
2-20-12
I have a complete 3.8L engine and transmission droppout I am parting out or will sell complete! ***THE ENGINE IS LOCKED UP*** But everything else is good. I do not have the power steering pump or ac compressor, but everything else is there. wiring, computer, other accessories, transmission, etc. make me offers on this stuff. I need it gone. Hell I'll sell it complete for $400. Picked up! NO SHIPPING AS A WHOLE DROPOUT! I'll ship the smaller parts if i have to part it out!
lmk
Thank You!
-James
Sure can. The spring is missing on the ash tray, the lid has a slit in the top part and the button is broken, the TCS button piece has 1 clip broken, but can be glued or replaced Cheap.
That's all the issues with it. Other than those, it's a nice console.
I'll get a pic up soon.
James
James
I don't man!
I know a buddy of mine has a whole rearend with 3.23's in it, so It'd definentally be a Series 3 carrier. It's a posi unit from a Trans Am. But the rearend has bad gear whine. He'd prolly sell the whole thing for pretty cheap. I think like $75. Or just pull the carrier and sell it if you didn't wanna pay for shipping the rearend. I can ask him if you want.
lmk
James
lmk
James
can you make me a deal on these parts and pm me your best price:
99+ LS1/T56 Engine Harness and PCM $350
Ebony T Top Headliner in Great Shape! $100
The wiring harness is pending sale, and the t top headliner is pending sale as well.
I will know for sure this weekend on those items. I will make a package deal on them. Are you picking these up, or will the need to be shipped?
lmk
Thank You,
-James
lmk
Thank You,
-James
