New Personal Best and Set The C6 M6 1/4 Record!
Big thanks to all the parties helping out. Mr. Fix It(Bill, 5litereater) is about as good as there is around. I guess not only being a mechanical engineer by trade, but knowing his stuff goes a long way. Also, I would like to thank Joe(username), Bryan(Flash), Inspector12(Jeff), Wally(Auto Adrenaline), Mike(Gforce) and some other guys I left out.
Wally fixed a ton of the issues on the tune, and fixed parts of the fuel system including a couple big leaks. Car ran extremely hard with his tune, and I took the car out 3 weeks ago for a test and tune. First pass hot off the street was a 10.08. Made 2 more passes, but missed shifts. 60fts stayed solid though, at 1.60-1.62's. Big thanks again to Wally for the hours spent helping me through a hard time, and staying up until sunrise working on my car for the Mile.
Had a debt to pay for borrowing a balancer from inspector 12. Went to Gforce to pick one up, and ended up throwing it on the dyno to read the boost. We also welded in a bung to read A/F since mine were unbreakable on the exhaust. Mike leaned the car out a bit.
Friday, I made back to back passes. 10.06 and a 10.07 when I hotlapped. Mike happen to be out at the track, and bumped the timing up 1-2 degrees from 16* when we waited for the light rain to pass in the middle of the evening. Here are the results.
(#3565 with me, 402, Novi 1500@12psi, full street trim with Fbody wheels on drag radials, 100% stock C6(non Z06) rearend, etc).
http://www.youtube.com/watch?v=i4I2Whp7sqc
http://www.youtube.com/watch?v=FQYHV...layer_embedded
And 2 of the 3 10.0 passes. :crazy:
http://www.youtube.com/watch?v=p3HFXYd65fg
http://www.youtube.com/watch?v=B5dsU2DbFU0
All in all, I'm very happy with the car. I made the #1 spot for a c6 M6(non Z06/ZR1) car, and have only about 20 passes in the car, and 6-7 with the new motor. No weight reduction, stock wheels(heavy fbody wheels out back), and an additional weight of the roll bar. I would love to have a track rental some time with a negative DA, but unlikely here.
I'm still pretty excited about it since I'm at 12 pounds of boost and still haven't used the bottle yet.
Thanks guys! Chris, will you upload that video to your youtube that you sent me? That way it doesn't kill the quality as much. Thanks for sending it to me!
i hit 9.74 almost 2 years ago with a h/c stock bottom end ls2 with a 150 shot m6. so maybe you haven't set the record just yet but seems you will soon either way, very nice run.
Thanks guys! Going by the ET list on Corvetteforum.
I'm going to be adding the bottle and giving it another shot soon. Hope to get deep in the 9's. Also, I will eventually add slicks and skinnies to the car, but I want to keep it a street car now.
right from cf since you have a 402.. you are in the "larger displacement" group
cammed C6 your 9s run isnt even listed there..
Larger Displacement (All entries)
09.513 @ 148.77 - Todd@RPM - 05 A4 -TT, 427cid, fuel sys, 3.42, L92 heads, RPM Trans, tune, DR - (4274)
09.650 @ 141.11 - Tluck - 05 A4 Z51 - 402cid, ccw drag pack, 373, N20 & more, tune, DR - (3926)
09.895 @ 138.76 - Blue RacerC6 - 05 A4 Z51 - SC LPE 427,N20 (100) & RPM trans, tune, DR - (4273)
09.950 @ 139.26 - Thesubfloor - 07 A6 – LS7, CAI, cb, conv, 3.42 H&C forged int, tune, DR - (4465)
10.082 @ 141.82 - Winters 97 GT - 08 M6 - 402, SC, alky, B&B mufflers, tune, DR - (5628)
10.369 @ 134.42 - Pete Champion Motors - 06 A6 – LS7, cam, cb, conv, fast, 3.15, forged int, ph, tune, DR - (5153)
10.416 @ 132.71 - RGSTOY - 07 A6 Z51 – LS7, conv, 3.42, hdr, tune, DR - (4194)
10.470 @ 130.89 - Craftfox - 07 A6 Z51 – 440cid, conv, fast, 3.42, hdr, tune, DR - (4444)
10.529 @ 138.03 - Icevettez06 - 05 M6 - 402cid, apsTT, alky, fast, hdr, qual, tune, DR - (5297)
10.689 @ 133.21 - Schilitj - 05 M6 Z51 - 402cid, SC, cb, H&C, hdr , tune, DR - (3525)
10.761 @ 128.59 - MCV - 05 M6 - Callaway 550 package gears, DR - (778)
11.439 @ 124.43 - Sheesnaz - 06 A6 Z51 - 416cid, conv, pfast, H &C, ptb, tune, Nitto Ivos - (3736)
11.689 @ 122.42 - RDD41 - 06 A4 - LPE 403 package - (658)
silly houston guys
