Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
435" Darton Sleeved LS1 w/ C5R heads
Old 01-08-2012, 10:26 PM
LS1TECH Sponsor
Jonathan@Tick's Avatar
Default 435" Darton Sleeved LS1 w/ C5R heads
Category: Engine - Complete Motors
Price: $10000
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): NC
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Engine is SOLD
At one time, this engine was in my 99 Trans Am. The car weighed 3350 lbs w/ driver then and this engine with less compression and a smaller cam ran 6.10 @ 110 in the 1/8 with a best of 9.70 @ 135 in the 1/4. This was with a th350 trans, 4.10 gears, and MT drag radials. This was 5 years ago.
The engine ended up wiping a lifter out. After sitting for nearly two years, we ended up selling it to a customer after rebuilding it to his specs for a small shot of nitrous. We upped the compression to just over 13:1 and upped the camshaft to a custom solid roller from Cam Motion with 264/274 duration @ .050". I don't recall the lift exactly, but it was around .720".
The customer was an over the road truck driver and basically never had time to run the car, and when he did it would break a new part of the driveline each time lol. After the last broken axle, we ended up purchasing the car. He did manage to make his Camaro run a 6.00 @ 120 mph in the 1/8 a couple of years ago with bad traction issues on MT radials. His car also weighed roughly 3300 lbs with driver.
On the chassis dyno through a very loose converter the engine did manage to make 598 rwhp on motor. With a 200 plate shot (carb style nos plate) it made 806 rwhp completely blowing through the converter. The converter would flash to 7200 rpms, so I'm sure it would have made much more power if we had ever dyno'ed the car with a proper converter. This was also through 3" exhaust to the axle with Imco single chamber mufflers (flowmaster copies).
This engine was using all top notch components, but the rest of the customers car left much to be desired.... In the right hands this engine has 900+ rwhp capabilites and mid 8 second passes just like it is.
Shortblock details.
-435 cubic inches. 13.1:1 compression
-4" Callies Racemaster Crankshaft
-6.125" Callies Compstar Connecting Rods
-22CC Diamond custom 4.160" diameter dish piston with Total Seal ring package set up for 200 shot of nitrous. Tool steel pins.
-Darton Wet Sleeved LS1 Block by Steve at Race Engine
-Rollmaster dual roller timing chain
-Isky Redzone C5R lifters with EZroll bearing upgrade. Custom .150 offset for C5R heads
-ARP main studs
-Ported Melling HV oil pump
-stock oil pan with minor porting on oil passages to filter
Top End Components:
-C5R Heads with 38cc chambers and 2.18/1.62 titanium valves
-Comp 959 Roller Springs with 250lbs/700lbs open/close pressure
-Ports on back of cylinder head for external water pump (plugged off with pipe plug but can be used by unscrewing pipe plugs)
-Sb2.2 single plane manifold which was heavily modified and reworked for use on a c5r headed motor (ports are in similar location to sb2.2 head) at Pat Musi's shop
-Billet Fuel Rail
-Cometic 4.165" .060" thick darton MID wet sleeve head gaskets
-ARP Head Studs
-264/274 dur @ .050" Cam Motion custom camshaft. 113 LSA. Lift was around .720 using the following rockers... I can't recall the ICL
-1.95 jesel pro series c5r rockers
-Trend 3/8" pushrods (unsure about thickness off the top of my head)
-C5r valve covers with spring oilers. Oilers aren't currently hooked up.
Head Flow Numbers on 4.155" bore:
Intake:
.100 67
.200 150
.300 222
.400 295
.500 341
.600 368
.700 367
Exhaust with no pipe (about 274 peak with pipe):
.100 43
.200 111
.300 168
.400 207
.500 222
.600 227
.700 231
All that is necessary to complete this engine is an ATI balancer, some fuel injectors, a water pump, and a 4150 throttle body. I would suggest replacing the oil pan with a Moroso just for piece of mind. I work for Tick Performance in Mooresville NC and I assembled this engine. We can provide any of the additional needed parts and handle the install of the engine if desired. Certainly we can't warranty any race engine of this caliber, but you can trust that this is a good engine as my reputation would be on the line otherwise. If local to us, we'd be glad to go to the track with the buyer and help out any way possible.
Asking $10,000 . It would cost more than this to build a basic iron block 408 with some decent heads and budget everything else. Just the lifters, rockers and camshaft in this engine cost over $3000 new. C5R heads sell for $4000 a pair un-assembled. According to the previous owner, over $3000 was spent modifying the SB2.2 intake and fabricating the intake adapters. Darton Sleeves cost $2600 installed in your block. Custom Diamond pistons with tool steel pins were over $1000. Callies racemaster crank goes for over $1500. We're over $15,000 and haven't even covered the con rods, pushrods, gaskets, titanium valves, springs, main studs, head studs, port work, or machine and assembly fees. One could easily spend $20,000+ to duplicate this engine.
For more information call the shop at 704-660-5843.
Thanks,
Jonathan
Old 01-29-2012, 11:36 AM
LS1TECH Sponsor
I will take $8500 for this just to move it out of our way. That is a FIRM price. The top end alone is probably worth that...
Old 01-29-2012, 05:27 PM
86cutlass350's Avatar
are you looking for any parts for trade?
Old 02-19-2012, 09:45 PM
LS1TECH Sponsor
Bump. Not looking for any trades unless you have a chassis dyno
Old 02-23-2012, 03:25 PM
LS1TECH Sponsor
to the top
Old 07-20-2012, 10:51 AM
LS1TECH Sponsor
I still have this engine. Lowering the price to $7500 which is crazy cheap considering the cost of building any kind of complete longblock with heads of this caliber and a solid roller setup will cost double that...
Old 07-22-2012, 11:32 AM
TZ2884's Avatar
Bump for an engine I wish I could afford. GLWS.
Old 07-22-2012, 02:57 PM
Received 3,369 Likes on 2,085 Posts
I can't believe you still have this!!! Free bump.
Old 07-23-2012, 10:01 AM
VYSHSV8's Avatar
Would you ship to australia
Old 07-24-2012, 08:50 AM
brett walker's Avatar
I wish I had the cash! I'd love to have this motor!!
Old 07-24-2012, 12:05 PM
1badbirdy's Avatar
Free bump! Do u have any sound clips or videos of it running?
Old 08-06-2012, 11:28 AM
GOATGODPAN's Avatar
Anyone wanting to kill *ss at the track needs to jump on this. I spoke extensively to Jonathan about this motor and was very, very impressed. I wish there was a way it would fit my application (DD street lol).
bump for a monster motor
Old 08-20-2012, 03:24 PM
BLWN1's Avatar
So its Still available?
PM me my ss is pending..
Quick Reply: 435" Darton Sleeved LS1 w/ C5R heads
