Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2002 Camaro Z28 HKE 427 559 rwhp
Old 01-09-2012, 08:14 AM
General Jack's Avatar
Default 2002 Camaro Z28 HKE 427 559 rwhp
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $18000
Mileage: 60800
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
**************SOLD****************
I’ve decided to sell my 2002 Camaro Z28 with a LS 427, not an easy decision, but I need something a little more tame. It’s been fun, but this thing is a beast that I just don’t use enough (sadly). The car is running great, ran an 11.14 @ 127.8 a couple of months ago, DA corrected to a 10.96 @ 130.0. And that’s with a 1.7x sixty foot and a road racing rather than drag suspension under it. It’s a mid 10 second car with the right suspension, easily.
My goal for the car was near stock appearance and 10 second quarter miles. The 10 second barrier was a bit problematic because you have to have a roll bar for < 11.49, so really I only have 1 go at it per trip to the track because I get kicked out. Regardless, the car has met those goals. The other thing I tried to do was use the best components/builders/mods.
Engine was built from scratch by Erik Koenig at HKE back in 2009. It was an LS3/L92 aluminum block, bored and stroked to 427 cubic inches. TFS 235 heads, big cam, built for N/A only. I’ve put approximately 2,300 miles on the motor since then. It dyno’d 559 rwhp on a fairly conservative tune my Moe Bailey. Keep in mind too that this is through at Moser 12 bolt (4.10 gears). MN6 transmission was rebuilt and upgraded with heavy duty components at the same time as then engine build. I also added a Monster clutch and new flywheel at that point. The Moser 12 bolt was added back around 2005 or so, it’s got around 25,000 miles on it.
For the engine build, transmission rebuild and tune, I solicited advice from here on www.ls1tech.com and went with the most consistent recommendations. I wanted things done correct.
Parts list is below, I have documentation for most of what’s on the list, most importantly the engine. Total mods on the car cost over $20,000. And that doesn’t include the labor, lol.
Couple other things. I've been on LS1tech.com for many years and done several deals with fellow members. I bought this car brand new in Austin Texas in 2002 from Champion Chevrolet in Austin. It was my daily driver for about five and a half years, but was garaged almost every day (parking garage at office and garage at home). As a result, the paint is still in excellent condition. The interior is still in great shape, no tears, cracks, etc. The car does have a few exterior cosmetic flaws as I drove it every day but there’s nothing too serious, I can send pics of the flaws if you are a serious buyer. Odometer reads about 60,800 miles, but again, motor and rebuilt trans have about 2,300 miles on them.
Issues… not many, but it is a 10 year old car now. A couple of the speakers are blown, ABS light is on (because my rear tires are taller than the fronts), and the car is current on its inspection but is not currently emissions compliant: long tube headers and TSP true duals with X-pipe and Moroso spiral flows. It sounds wicked and shakes the house. I’ll miss that part.
Asking $18,000. This isn't a forced sale, just looking to go in another direction, I won't respond to low ball offers.
Parts list (I have most receipts but not all, I do have the important stuff like the HK build sheet and Moser 12 bolt invoice).
Engine
  • HKE 427 - I have the build sheet, the highlights are as follows:
  • L92 aluminum block
  • Scat 4340 crank
  • Scat 4340 I-beam rods
  • Wiseco custom pistons & GFX rings
  • ARP bolts & studs throughout
  • TFS 235 heads
  • 254/262 cam / 112+3
  • Yella terra 1.7 rockers
  • Manton custom pushrods
  • Double roll timing chain
  • Total $8,827
  • FAST 92 intake manifold , gaskets & seals $1,228
  • Ported Throttle body $250
  • Fast toys 85 mm lid $130
  • Various parts for LS1 / LS2 conversion
  • (oil pump, sensors, timing chain cover, etc.) $500
Transmission
  • Rebuilt with the following:
  • Basic rebuild kit
  • Snap ring set
  • New synchros
  • Billet keys
  • Steel shift fork for 3-4
  • Bronze shoes
  • Total ~$800 (Parts only)
Drivertrain
  • Monster Clutch and Lightweight flywheel $970
  • U joints and drive shaft balancing $200
  • Moser 12 bolt w/ 4.10 gears & 33 spline axles $2,200
Exhaust
  • Kooks 1 7/8” long tube headers & accessories $790
  • TSP true dual exhaust $479
Fuel
  • FIC fuel injectors 42 lb $234
  • Walboro 255 lph fuel pump $100
  • Hot wire kit $??
Chassis & Suspension
  • Drive shaft loop (not installed) $??
  • Koni single adjustable shocks (front and rear) $1,000
  • Strano sway bars (front and rear) $579
  • BMR Adjustable Rear LCAs $210
  • ZR1 wheels $600
  • M&H Racemaster drag radials $425
Other
  • Tune $400
  • Gauge pod with oil pressure and water temp $150
  • Dual catch can set up $150
Attached Thumbnails 2002 Camaro Z28 HKE 427 559 rwhp-img_4742-v2.jpg   2002 Camaro Z28 HKE 427 559 rwhp-img_4745-v2.jpg   2002 Camaro Z28 HKE 427 559 rwhp-img_4746-v2.jpg   2002 Camaro Z28 HKE 427 559 rwhp-img_4747-v2.jpg
File Type: pdf
Old 01-10-2012, 05:31 PM
ttt...
Old 01-10-2012, 07:34 PM
tones2SS's Avatar
Great looking car Jack. That is the ultimate looking "sleeper".
GLWS
Old 01-10-2012, 09:05 PM
Thanks, that was the idea!
Old 01-11-2012, 12:13 AM
glhs422's Avatar
Very clean! GLWS.
Old 01-11-2012, 11:53 AM
BLWN1's Avatar
Like to have it, just out of my budget at the moment...
Old 01-11-2012, 01:11 PM
nicksevo's Avatar
Very nice car ..especialy for the price...wish I could get a car now but gota wait till next spring... and is it a track only car? Or does it have.good street mannors? And thee rings are gapped for n/a or are they solid?
Old 01-11-2012, 06:17 PM
Thanks. Car has good street manners after warming up. On cold starts it will stumble and hunt a bit, sometimes its fine sometimes I have to give it some gas to keep it lit. After warm up does very well considering the size of the cam, I do have to put the clutch in from time to time to get the rpms back down to idle when rolling to a stop, but that's about it.
I've only been to the track 3 times with this motor, total of about 12 passes. Driven about 2,300 miles on the street, so its been much more of a street car than track car.
Motor was built strictly for N/A, especially related to the rings specs and placement.
Old 01-11-2012, 08:41 PM
brokeLS1owner's Avatar
sick car, if it was a ws6 id be on my way but ive always been partial to the ta. good luck with sale. this is one badass ride
Old 01-13-2012, 06:58 PM
ttt...
Old 01-13-2012, 11:00 PM
99f1's Avatar
Default ttt
does the title say z28? or was it a 6cyl b4? or did you paint the sail panal and rear views? pleeze...more detailed pics....mint car
Old 01-13-2012, 11:32 PM
Yes, it is a Z28, I purchased it brand new in early 2002. Title is in hand.
I'm going to post more pics this weekend.
Old 01-14-2012, 01:01 AM
99f1's Avatar
Default ttt
you didnt paint the sail panel?? i thought they all were black? im sending you a pm
Old 01-14-2012, 01:24 AM
Black FormulaLs1's Avatar
one hell of a sleeper...and for less than the price of a new stock SS to boot..damn nice build!
Old 01-14-2012, 08:44 AM
No paint on the sail panel. I'll post additional pics today.
Thanks!
Old 01-14-2012, 09:12 PM
99f1's Avatar
Default ttt
pics and vid would be great
Old 01-14-2012, 10:43 PM
Old 01-15-2012, 06:22 PM
bump...
Old 01-16-2012, 04:22 PM
ttt...
Old 01-17-2012, 10:29 AM
ThaBirdMan's Avatar
I love this car. Wish you wanted a vette.
Quick Reply: 2002 Camaro Z28 HKE 427 559 rwhp
