Wiring up 98 Gauge Cluster
Trying to figure out how to wire up a 98 gauge cluster with my ls1 swap. I made a table of the pinouts for the 98 cluster and what I think Im suppose to splice into. Still need to figure out my stock cluster pinouts, what to do with the "power feed" and "i/p illumination" pinouts.
PCM pinouts are from a 99-02 Fbody.
"3rd Gen" are spliced from my stock gauge cluster connectors.
Does this seem right? And any help with the power feed and illumination pinouts would be great.
adfljansdfbhasdnfkjasdnfkjansfdkansklfanfsdnadflna fnfsdjkfdl
I just had it all typed out and it freaking dumped it...... AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHh
Brb...
Brb...
A1 - Ignition/Switched power supply
A4- PCM supplied Check engine light Signal
A5- Ignition/Switched power supply
A6- PCM will send a signal for this if you decide to use it
A10- Parking brake and low brake fluid level supply a ground to this pin when there is a problem and the "Brake" light illuminates
A13- Constant power supply- likely not necessary, only appears to supply "Security" light
B1- Signal from headlight switch when headlights are on- cluster backlighting
B2- Signal from Dimmer switch- Adjusts backlighting intensity
B3-Ground
Hope this helps, Ask if you need any additional info.
Mark
B3-Ground
Mark
