85mm MAF Question
Old 01-12-2012, 12:21 AM
Joker98's Avatar
Default 85mm MAF Question
I thought that I read on here at one point that a 98 PCM wont work with a 85mm MAF?? Am I mistakin? Can anybody confirm this?
Old 01-12-2012, 06:37 AM
ramairetransam's Avatar
you need a 5 wire to 3 wire adaptor and your pcm needs to be tuned for it . Do not buy a slp maf they suck , but the pcm needs to be tuned to run it correctly .
Old 01-12-2012, 09:31 AM
Moderator
jimmyblue's Avatar
The thing about 85mm MAFs is, they get to max freq at
lower air mass than the stock 75mm (459g/sec @ 12kHz)
but earlier PCMs don't run all the way out to 12kHz in the
MAF table - or so I recall. So your air mass is likelier to
hit a limit value early, in effect.
Old 01-13-2012, 11:59 AM
Project Revision's Avatar
This area seems likely to be able to answer my question so i'm going to throw it out there.....I have a 2001 Trans am harness (donor; in a 1968 firebird) connecting to an LS2 Magnacharger that fits a 2006 GTO....questions is this - I need to purchase a MAF housing ....will I need some sort of adapter to connect the 2001 ECM to the 2006 MAF??? Thanks in advance for any help!!
Old 01-13-2012, 04:51 PM
Moderator
jimmyblue's Avatar
The connectors are different at the MAF, and you may
want to use the in-MAF IAT which accounts for the extra
two pins, or not. Casper's sells adaptors and pigtails for
soldering, or you can cut one off at the boneyard. The
calibrations differ, that's a trivial tuning thing. But you
want an idea of whether you are going to max out the
MAF g/sec, 75mm limits at 511g/sec while 85mm clip at
about 459g/sec.
Now if you intend to run boosted you really want more
than the 1-bar MAP, and all the 2-bar OSes I think are
speed density only so a 3-1/2" piece of pipe might do
as well.
