First Pics PRC 220cc As Cast Cathedral Heads INSIDE!!
Old 01-12-2012, 04:25 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default First Pics PRC 220cc As Cast Cathedral Heads INSIDE!!
Guys we've been working for about 5 months tweaking the all new PRC 220cc as cast runner program. We hope to have them available in about 90 days!
Each set will feature the 6 bolt PRC castings, Manley valves, PRC Spring kit, and will have cnc chambers & cnc shaped guides for optimal flow!
Testing has show 320cfm+ capabilities out of the as cast port!!
Enjoy
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 01-12-2012, 04:28 PM
RezinTexas's Avatar
Nice!
Do you have price and CC volume specs?
Old 01-12-2012, 04:32 PM
The Scammer Hammer
dr_whigham's Avatar
Jason,
what size was the test bore?
How would they do on a 346?
Old 01-12-2012, 04:33 PM
They are built for 3.9-4" bore applications & are 62cc before milling.
__________________
Jason
2005 Twin Turbo C6
Old 01-12-2012, 05:55 PM
mac62989's Avatar
Interesting
Old 01-12-2012, 06:17 PM
krissoto's Avatar
Very nice product.
Old 01-12-2012, 07:29 PM
redsilv's Avatar
Talking
hump:
Wheres the flow numbers?
I bet good low/mid lift?
I just got off your web site looking at the stage 2.5 ls6/cam combo
for my 370 lq9 short block
Old 01-12-2012, 10:11 PM
98blueSScamaro's Avatar
Bolt them bad boys on Aarons car and let it eat....... This will be a great head for my tbss.
Rob
Old 01-12-2012, 11:46 PM
wildcamaro's Avatar
Nice heads, with a little bit of work with so
E sanding rolls they would be even better
Old 01-13-2012, 12:19 AM
Turd Gen Guy
1nasty86's Avatar
Thought of a price on these yet? Tfs as cast 220's are 1679 so priced accordingly OR CHEAPER im sure these heads would sell nicely.
Old 01-13-2012, 01:47 PM
Sales2@Texas-speed's Avatar
They will target a similar pricing range, but are designed to out perform ANY as cast cylinder head on the market by a pretty nice margin!!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 01-13-2012, 01:50 PM
Detoxx03's Avatar
Those are very nice.
Old 01-13-2012, 02:16 PM
Turd Gen Guy
1nasty86's Avatar
Pretty big claim as to outperform the trickflow as cast, hope they turn out good for you guys.
Old 01-13-2012, 04:11 PM
Pulse_GTO's Avatar
Will they work better on a 3.90 bore strikers than your 2.5 LS6 heads?
Pulse_GTO's Avatar
Will they work better on a 3.90 bore strokers than your 2.5 LS6 heads?
Old 01-13-2012, 04:56 PM
JPH
JPH's Avatar
They look very good and I am sure will perform just as well. Do you have any closeups of the combustion chamber?
Old 01-13-2012, 05:40 PM
Cape T/A's Avatar
Sounds like this is the head for me! Now someone just needs to talk my wife into letting me spend some more money on the T/A!
Old 01-13-2012, 06:44 PM
mac62989's Avatar
Hmmm, You guys gonna be having any dyno numbers with them?
Old 01-13-2012, 08:44 PM
garygnu's Avatar
whats the valve angle ?they look nice .what do they weigh each ?can the be done with power metal guilds ?how dose the port align with a fast intake ?
Old 01-13-2012, 08:51 PM
Sales1@Texas-speed's Avatar
Im unsure on exact weight, but our PRC aftermarket castings come standard with 13 degree valve angles. We do offer a powdered metal guide option if the customer requests it. I will also add that intake port alignment with the FAST is very nice!
Quick Reply: First Pics PRC 220cc As Cast Cathedral Heads INSIDE!!
