Nos mini progressive controller?? (wiring)
Need some help, would like to have someone tell me how to wire this up on a f-body. Had this on a carb motor and worked fine but not sure my car. Also have the lnc-002 on there if that matters.It will be for a single stage. Just want wiring instructions with a wot switch.
Would like to put the progressive on a toggle switch and keep my wot switch. The only time i use it is on street. I know u can chenge it to 100 percent all the time but right now she works like a champ.
Guess Im not following ya here, bc you can set it however you want. You don't have to use the progressive, or any of the options. You can set it however you want. Use the toggle to activate it and done. U can set everything at 100% and and zero out the window switch. Gotta keep it simple
FOR WOT SWITCH ONLY:
WHITE - To positive side of arming switch
BLUE - To Ground side of both Solenoids
WHITE/BLUE - To WOT Switch on Throttle Body
Note: I would set TPAS to 00; one side of the micro-switch to
ground and on trigger to the WHITE/BLUE wire.
YELLOW - To negative side of Relay for solenoids
GREEN - Directly to Ground. Set window to .00 and .99
BLACK(small) - Ground
BLACK(large) - Ground
Only used for two stage:
ORANGE - Tape off unless using a two stage
WHITE/RED - Tape off unless using a two stage
Instructs at this Link:
NOS Mini 15974 Dual Nitrous Controller
The other option is you can hook it up to either a negative side of a coil or the PCM pin. If you use the PCM pin, the rpm tach setting is 04, otherwise I think they mention 01.
If I were you , I would hook up the window switch in case you want to use it later and set it from 0-9900
