NX's Throttle Bodies Are Here!!!!
Ok guys there are 15 units in. Nx is doing some final testing and they are ready to go. They will be driving around for the next day with it on to make sure everything is good to go. Some units may show signs of being bolted down because they are testing each one before shipping.
Here is what makes this a unique piece:
1.The throttle body has a Vortec Swirl cut in.
2.There are no re-used parts. ALL PARTS ARE NEW.
3.They used bearings instead of bushings for the throttle shaft to sit on.
4.All parts are made of 60-61 aluminum and Stainless (No Brass)
5.The screws that hold the butterfly are locktited and the backs arecuted and pinged over so they will not back out.
6.All are hand assembled
7.The throttle stop has an adjuster screw.
8.The units are 85MM. They will bolt to a stock throttle body with the use of an adapter.(The adapter comes with the bracket to relocate the throttle cable. Gaskets and Bolts)
Here is the price:
The throttle body is 499.00.T he adapter is 60.00. Yes this is pricey,but you pay for quality and speed. Call in your order now at Nitro Daves 1-866-648-7637. There are only 15 available.
Dave
Here is the price:
Dave
Dave
Dave
May be a dumb question but, do the Nx lines run to the throttle body or does it not have it incorporated into it. It kinda seems stupid for a nitrous company to put out a product that has little to do with the nitrous part of it.
seeing as they made it a custom bolt pattern, they kind had to build a TB to work with it.
I think they designed the part for the intake, and the fact they can sell it to general users, as a upgrade, is a nice bonus
Ryan.
