Pontiac GTO 2004-2006 - driveshaft to pinion plate bolts
View Full Version : driveshaft to pinion plate bolts
EfSeeThreeEs
01-20-2012, 10:53 AM
hey guys, ive got a little issue at my hands here. i just recently put a .600 lift 224r comp cam and a mcleod twin disc into my 04. now, everytime i launch, i either shear the bolts for the drive shaft to pinion plate( one piece driveshaft from the driveshaft shop) or i snap the cv's. ive done some research, ive seen aviation grade bolts? is that necessary? and also all ive found for the axles are 1000hp axles for $1200, are there any other options?
thanks in advance for the help.
pete
mark21742
01-20-2012, 12:29 PM
Don't know if it helps, but I am in the middle of my 4link and 9" solid axle swap in my 04....I hope I don't break this one lol
mark21742
01-20-2012, 12:31 PM
Just curious, what are your 60' and 1/4 times?
chance575
01-21-2012, 10:57 AM
see gforce for your needs..........or put some street tires on it and spin them instead of snapping stuff
I upgraded to a hendrix 8.8
scphilli
01-21-2012, 11:41 AM
I would contact the drive shaft shop and ask them why their DS can handle a cammed LS1. They may have some hardened bolts for cammed applications. Also, if you don't need the 1000hp, you can get a set of aftermarket axles for about half the price. Or, even 05/06 axles, which are a little stronger than the 04s.
my first GTO
01-21-2012, 03:47 PM
I have a Driveshaft Shop Shaft and NEVER had a Problem with it, we're the Bolts tight?
scphilli
01-21-2012, 08:11 PM
Even loose it doesn't make sense. The OP was just before lunch so it could have been a wake-n-bake on an empty stomach issue.
mark21742
01-22-2012, 12:48 AM
I just can't see the right bolts breaking, specially with a smaller cam and average launch rpms....maybe bad batch of bolts?
svede1212
01-22-2012, 08:48 AM
Loose or not would make a big difference. Loose just the bolts are holding it. Tight the friction of the two pieces hold it. Bolts snapping are extremely unusual with even very high HP cars with very quick 60s. Something else is wrong here, install, wheelhop, something.
gconnoyer
01-23-2012, 10:19 AM
...what grade bolts are you using?
I don't think that shit should be breaking every time though. I've launched the fuck out of mine on slicks, and never broken anything on the stock driveline.
EfSeeThreeEs
01-23-2012, 01:19 PM
off the top of my head right now, im not sure about my 60's. i havent ran the new set up at the track yet. my 1/4 before the cam with 150shot nitrous was a 12.2. theyre grade 8 bolts. and this is on street tires....275/55/17 bfg gforce sports. the wheel hop is horrendous, but thats my axle problem. i checked out gforce and found nice anti hop axles that im gonna pick up. stage 1s should be fine. but this is the second time my driveshaft bolts broke.
and sorry about the delay response, ive been insanely busy latley...
EfSeeThreeEs
and yes, tight with locktite
mark21742
01-23-2012, 01:38 PM
Could the bolts have had too long of a shank on them so they felt tight, but not really clamping the to two peices tight?
402GOAT
01-23-2012, 01:47 PM
imo if you had wheel hop, which is a very violent thing to occur, then that is what caused the bolts to break. wheelhop is caused by tire spin. upgrade to a better drag radial like a mickey or hoosier and i would be doing some drag bags and/or harrop differential cover. there is many more upgrades that can be done to the suspension that will help eliminate wheelhop also
EfSeeThreeEs
01-23-2012, 02:10 PM
well ive got drag bags. they work on the strip but i cant get the street figured out. as for the shank, theyre the exact same length as the originals. i had measured them up
svede1212
01-23-2012, 06:49 PM
Grade 10.9 would be more appropriate and wheel hop will kill just about anything. The problem on the street is if you can spin you can wheel hop. If the tires don't they won't. Tires, shocks, springs, bags, bushings, solid drive shaft, Harrop cover and differing diameter half shafts are all partial solutions that need to be mixed or matched for good results
EfSeeThreeEs
01-23-2012, 09:10 PM
ok, so what are some successful set ups that you guys have seen/used?
2004yjgto
I have a DSS shaft with BMR axles and putting 650rwhp to the set-up no problems at all. I would say try to have someone else check your work just as a precaution
my first GTO
01-23-2012, 10:51 PM
I run the DSS shop, driveshaft and stubs with axles also my 8.8 center is a Hendrix with over a 1,000 hp to the rear wheels and the GTO does a 1.40 60 foot times the Top 3 guys run the DSS parts or Hendrix parts...
gconnoyer
01-24-2012, 10:09 AM
Traction
/wheelphop problem.
The rest of the parts are DEFINITELY necessary upgrades when you start making power, but the real way to get rid of the wheelhop is traction.
Slicks or Good Drag radials.
EfSeeThreeEs
01-25-2012, 09:15 AM
Welp time to start my research, thanks for all the help guys. I'll have more questions soon for you all!!! Lol
mebuildit
01-26-2012, 02:37 PM
I buy aircraft hardware from coastfab. They have everything that I have ever needed.
