where you guys buying ported 317s?
Old 01-20-2012, 01:23 PM
T/AWS6969's Avatar
Default where you guys buying ported 317s?
Trying to get options on where to get my heads...thanks
Old 01-20-2012, 05:58 PM
FrankieD's Avatar
Patriot Performance
https://www.patriot-performance.com/...ome.php?cat=35
Old 01-20-2012, 07:39 PM
T/AWS6969's Avatar
I've actually been told twice now from 2 engine builders do not buy patriot heads.
Old 01-20-2012, 10:56 PM
SPRAYED 01's Avatar
Try texas speed
Old 01-20-2012, 11:19 PM
T/AWS6969's Avatar
I was thinking texas speed but was wanting more options.
Fbodyjunkie06's Avatar
Buy a set of junkyard 317's take them to a guy that ports heads.
Old 01-21-2012, 12:39 AM
95maroz28's Avatar
what wrong with the patriots? i was considering a set since they seem affordable and should flow well. would be better off with reg 317s?
Old 01-21-2012, 12:57 AM
T/AWS6969's Avatar
I was told they have had casting problems....
Old 01-21-2012, 01:34 AM
L92 fox's Avatar
I would send them to AI. They do awesome work. I have a set of 04 317s that im not going to use. I would let them go for 100 bucks or so. Not trying to hijack, im just trying to help someone out.
Old 01-21-2012, 03:11 AM
tripblackls1's Avatar
West coast cylinder heads
Going to be a Lil more pricey then other options but they are the BEST
Old 01-21-2012, 01:59 PM
97_C5's Avatar
If you had the extra cash, tea has ported trick flows for comparable price to tsp ported 317's and they have a thicker deck.
Old 01-21-2012, 02:03 PM
RacerXLs1's Avatar
Tea has a nice set.
Old 01-21-2012, 03:42 PM
NightmareTA's Avatar
This is what I was thinking as the best and possibly cheapest option. A set of 317's should run no more than $200 or so used, and porting with a rebuild should still be less than a new set from patriot or any other place.
Old 01-21-2012, 04:09 PM
zapp109's Avatar
Just curious why you want ported 317s? I got 317s and im aiming for 1000 HP untouched.
Old 01-21-2012, 04:16 PM
02blackbeauty19's Avatar
Get a set of stock 317's, have them cleaned and do a good 3-angle valve job on them and put them on.
Old 01-22-2012, 01:19 AM
Probably because they will make more power?
Old 01-22-2012, 01:29 AM
WS6HUMMER's Avatar
I didnt know Patriot casted 317's?
I had patriot do the machine work on my 317's, no port work but very happy with the work. Will probably have them do all the machine work on my future motor build. Very nice people, & fast turn around.
Old 01-22-2012, 01:31 AM
L92 fox's Avatar
If you are running boost I don't know if porting your heads helps a ton like it does on a N/A set up, but im by far not a expect, so I could be wrong.
Old 01-22-2012, 01:33 AM
WS6HUMMER's Avatar
Oh yeah you could take them to Meaux In Abbevile La. but you would have to pay and get on a long list.
Old 01-22-2012, 01:34 AM
95maroz28's Avatar
i agree id rather have 600 with 10psi than 12 or so. so no go with the patriots then? guess ill use stock 317s till i need thicker deck
Quick Reply: where you guys buying ported 317s?
