806 cnc ported slp heads good or bad?
i recently purchased a set of these heads cheap but i cant find anything on then i have a 2002 ta m6 and i just bought a torquer v2 kit and LTs are these heads worth putting on in place of the stock 241s
your coil packs off your 02 will bolt right on, just have to flip one of them if i remember correctly.
as long as they are ported correctly. a hack job hand port can actually lose flow in the port rather than increase it. so be cautious.
EDIT: I see they are SLP ported heads. if that is the case, you should be good to go for some decent gains. however, just make sure someone didnt market these as SLP heads when they are infact hand ported heads...
Not saying hand porting is a bad thing, you just have to know what you are doing.
