G-Body Cold Air Intake Setups
Old 01-21-2012, 08:23 PM
Stoney667's Avatar
Default G-Body Cold Air Intake Setups
What are you guys doing for intakes? Where you got it, how much, etc. Post pics please!!
Old 01-21-2012, 08:52 PM
01cherryreds10's Avatar
I've got a pieced together kit from www.intakehoses.com. It's a 4" rubber to the 4" pipe and then a reducing 90 degree elbow down to a 3.5" pipe which connects to my 85mm MAF then to an autozone Spectre filter. You can see it in my build thread somewhere around here, ill post a picture when I get to a computer.
Old 01-21-2012, 10:40 PM
Hunter79764's Avatar
I just fit the MAF onto the throttle body and a generic 4" cone filter onto the MAF for now. Probably piece together some PVC or something equally cheap and redneck at some point.
Old 01-22-2012, 02:13 AM
bwirolla64's Avatar
I am making my own cold air box! I am fabricating it out of thin metal and 4" tubing. It's going in an Impala with a LS3
Old 01-22-2012, 08:30 AM
LS1 pwrd NOVA's Avatar
Anyone have pics? Ill need to do this soon also.
Old 01-22-2012, 11:31 AM
bwirolla64's Avatar
I'll post some in a few hours
Old 01-22-2012, 03:24 PM
bwirolla64's Avatar
here are a few pictures of what I am doing at the moment. I am also building a lid with a clear plastic cover so you can see the filter. It will also have an opening through the radiator support into the box for cold air.
Attached Thumbnails G-Body Cold Air Intake Setups-mock-box.jpg   G-Body Cold Air Intake Setups-intake-box.jpg   G-Body Cold Air Intake Setups-intake-2.jpg   G-Body Cold Air Intake Setups-intake.jpg
Old 01-22-2012, 11:18 PM
Old 01-22-2012, 11:21 PM
the_merv's Avatar
Not really a way to get cold air here..
Old 01-23-2012, 09:52 AM
spacemanspif's Avatar
I bought the spectre intake for trucks/suvs. Filter is a bit big but works pretty well. Think it was $150 off the shelf at one of the parts stores...bought it quick because I thought my car was almost done...5 months ago lol
Old 01-23-2012, 11:22 AM
bwirolla64's Avatar
How are you guy getting cold air in to the engine compartment? Do you have ducting running up to the filter? Otherwise it not a COLD AIR just an intake.
Old 01-23-2012, 06:14 PM
Stoney667's Avatar
Okay so maybe not cold air setups. Just intake setups in general. Just looking for intake setups.
Also can you list the parts that you bought and where you bought them?
Old 01-23-2012, 06:21 PM
the_merv's Avatar
You still going with a plastic Intake or aftermarket?
Old 01-23-2012, 06:22 PM
bwirolla64's Avatar
Well like cherry said intake hoses.com has some good stuff that I have bought as well as summit racing. It all depend on where you want to run it and how you want it to look. When I have my pipe where I want it I have to have a shop bend a 4" aluminum pipe so I can weld my MAF bung to it!
Old 01-23-2012, 06:25 PM
MikeFSKSpeed's Avatar
I have Vibrant Polished intake tubing in 2.5', 3", and 4"
I have Vibrant Rubber couplers as well as the Silicone couplers and bends and K&N filters for any intake needs.
Old 01-23-2012, 06:48 PM
veltboy618's Avatar
I can not see any photos that are attached to the replies on this forum. I guess the system is messed up. Can you email me those photos to veltboy618@yahoo.com
Darius
Old 01-23-2012, 09:05 PM
the_merv's Avatar
Back before I did the Vic Jr. Swap mine was setup like this..
That side of the Core Support was cut and pushed in like a little door, deflected cold air into the Filter. That is a true CAI.
Old 01-24-2012, 12:18 PM
That was my thought. Seems like using flex would be the easiest to route and would let you place the filter wherever you wanted for the most temp. benefit. Just doesn't get the same reaction as a handmade, TIG welded CAI pipe.
With the budget I'm on, I think I have some extra dryer vent tube laying around and some hose clamps. Might get it done this weekend. Either that or make some sort of shield to get the hot radiator air deflected under the filter I have. These 170° intake temps are really killing the performance...
Old 01-24-2012, 12:55 PM
the_merv's Avatar
Dang..even with the Vic mine are 130-140.
Old 01-24-2012, 02:18 PM
2Aspire's Avatar
This is a cut and paste from another thread I posted on Cheap CAI ideas but also relevent since mine is a G-Body.. (86 Monte SS)
I used a piece of ABS plastic to create a separation from the engine area and the nose of the car..
While the ABS gave some support to the Aluminum end, It needed more, so I added a bracket, that cant be seen, because its bolted on the under side of the aluminum tubing down to the car.
Used this place for the aluminum tubing, rubber hose and clamps..
http://www.intakehoses.com/
Bought the air filter from Autozone..
I was happy with the end result... Was cheaper than say Mandrel bent tubing but certainly not the cheapest.. But its durable enough and will last long enough to justify the expense....
Quick Reply: G-Body Cold Air Intake Setups
