AP-Engineering LS6 Race head
Under criminal investigation for fraud
Well here are some numbers for our LS6 race head. Just got off the flow bench last night with these. Here are the spec's:
LS6 castings
Manley 2.080 stainless steel intake valves
Manley 1.600 stainless steel exhaust valves
Comp Cams titanium retainers
Comp Cams 978 springs
Bronze guides
teflon seals
Intake Flow numbers
.100" / 78.8 cfm
.200" / 163.9 cfm
.300" / 221.7 cfm
.400" / 275.9 cfm
.500" / 310.7 cfm
.550" / 323.2 cfm
.600" / 332.6 cfm
.650" / 338.4 cfm
This head was flowed on a 4.125" bore w/ a radius inlet and was tested @ 28"
Exhaust flow numbers
.100" / 65.4 cfm
.200" / 114.1 cfm
.300" / 163.0 cfm
.400" / 207.7 cfm
.500" / 251.0 cfm
.550" / 263.7 cfm
.600" / 266.8 cfm
.650" / 269.6 cfm
The exhaust was flowed with a tube
If you have any questions please feel free to ask.
Thanks,
LS6 castings
Bronze guides
teflon seals
Intake Flow numbers
.100" / 78.8 cfm
.200" / 163.9 cfm
.300" / 221.7 cfm
.400" / 275.9 cfm
.500" / 310.7 cfm
.550" / 323.2 cfm
.600" / 332.6 cfm
.650" / 338.4 cfm
.100" / 65.4 cfm
.200" / 114.1 cfm
.300" / 163.0 cfm
.400" / 207.7 cfm
.500" / 251.0 cfm
.550" / 263.7 cfm
.600" / 266.8 cfm
.650" / 269.6 cfm
Thanks,
6600 rpm clutch dump of death Administrator
Looks good. A couple of questions/requests.
1. Runner volumes
2. Bench used
3. Can you flow them on a 3.9 fixture?
Thanks, and keep up the good work.
1. Runner volumes
2. Bench used
LS6 castings
Bronze guides
teflon seals
Intake Flow numbers
.100" / 78.8 cfm
.200" / 163.9 cfm
.300" / 221.7 cfm
.400" / 275.9 cfm
.500" / 310.7 cfm
.550" / 323.2 cfm
.600" / 332.6 cfm
.650" / 338.4 cfm
.100" / 65.4 cfm
.200" / 114.1 cfm
.300" / 163.0 cfm
.400" / 207.7 cfm
.500" / 251.0 cfm
.550" / 263.7 cfm
.600" / 332.6 cfm
.650" / 269.6 cfm
Thanks,
LS6 castings
Bronze guides
teflon seals
Intake Flow numbers
.100" / 78.8 cfm
.200" / 163.9 cfm
.300" / 221.7 cfm
.400" / 275.9 cfm
.500" / 310.7 cfm
.550" / 323.2 cfm
.600" / 332.6 cfm
.650" / 338.4 cfm
.100" / 65.4 cfm
.200" / 114.1 cfm
.300" / 163.0 cfm
.400" / 207.7 cfm
.500" / 251.0 cfm
.550" / 263.7 cfm
.600" / 332.6 cfm
.650" / 269.6 cfm
Thanks,
1. Runner volumes
2. Bench used
1. Runner volumes
2. Bench used
Yep, I did make a typo, my bad. I corrected it know, thanks Chris.
These heads were flowed on a Super Flow 600
I will get you runner volumes in the next couple of hours. Also the chamber sizes of unmilled heads. We basically can get you chamber sizes from 68cc down to what ever you want to mill them too.
I will try to get them on the bench tonight with a 3.9 bore and will give you the results as soon as I get them.
Thanks for all of the questions.
WOW, absolutely amazing. You guys keep pushing the envelope, and the communication and customer service are second to none. Congrats.
I know who I'll be talking to for my next motor.
Bad30th
Bad30th
