Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
SOLD!! 2000 Trans Am 727Rwhp (Mecham Clone)
Old 01-26-2012, 09:57 AM
BoostAntiDrug's Avatar
Default SOLD!! 2000 Trans Am 727Rwhp (Mecham Clone)
Year: 2000
Make: Pontiac
Model: Trans Am
Price: $15500
Mileage: 136000
Private or Dealer Listing: Private Listing
Location (State): SC
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
It has a brand new LS6 347 with diamond pistons, eagle H-beams, clevite bearings, and ARP bolts everywhere possible. After a month and some break-in driving, on went the D1SC Procharger, methanol kit, then the tune. The engine has around 3000 miles on it now and 4 oil changes. I'm not sure how many miles are on the supercharger since I purchased it used. Im not on here often so text is the fastest way for pics/vids and info. 864-921-4532 Thanks
The complete mod list from memory:
Engine:
347 w/LS6 block and stock crank
Diamond -4cc pistons
Eagle H-beam rods
Clevite rod/main bearings
ARP rod/main bolts and ARP head studs
stock 317 heads
Manley Dual valve springs (.660 lift)
Yella Terra Roller Rockers
Comp Cams Pushrods
Comp Cams Lifters
Double Roller Timing Chain set
LS6 ported/shimmed oil pump
TSP Custom Grind blower cam (spec'd by PredatorZ)
Edelbrock Vic Jr. EFI and elbow / Nick Williams 90 Throttle Body
Pacesetter ceramic coated Long Tube headers
TSP true duals
Vengeance Racing Anodized catch can
ABS Delete
Power Adder:
D1SC Procharger w/8-rib setup and 3.4" pulley(17psi)
ATI Super Damper
3" Aluminum Piping w/ 3" Front Mount Intercooler
SNOW Stage II progressive methanol kit
Mondo Bypass Valve
Walbro twin 255lph pumps
Motron 60lb flowmatched injectors
Aeromotive Fuel Pressure Regulator
Edelbrock Black Fuel Rails
Transmission and Suspension:
TICK built Stage II T-56
TICK Master Cylinder
Pro 5.0 shifter
McLeod RST twin disc clutch w/slave
UMI Adjustable TQ arm/ adjustable LCA's/ PHB
QA1 12-way adjustable rear shocks
UMI Subframe Connectors
Cosmetic:
Eibach Pro Kit
15% window tint
Triple gauge A-pillar
Aeromotive Gauges - boost/fuel pressure/Air Fuel
Mecham Hood (car is a Mecham Clone)
Summit Aluminum Sport Mag Wheels
Mickey Thompson 275/60/15 (700 miles) 165/15 in the front
The car dyno'd last year at 727hp 646ft lbs of torque after tuning from V8muscle.net. It runs very strong, but has great street manners. Only thing that is annoying about street driving is how loud the car is with the true duals. The car does not have cam surge, or buck at all when traveling at low speeds. V8muscle did an extensive street tune on the car to ensure the best possible drivability and i've been very satisfied.
BoostAntiDrug is offline
Old 01-26-2012, 04:17 PM
Come on guys really nice car at a good price. Trades will not be frowned upon. Im looking for anything from an 03-04 cobra, to anything turbo.
Old 01-27-2012, 12:45 PM
Dixon79lt's Avatar
Tried to buy this car.. sounds like you were the guy with the vette! lol
Dixon79lt is offline
Old 01-27-2012, 04:08 PM
That's correct. Now I have a baby on the way and its gotta go lol fixed somethings and even upgraded the car and selling it cheaper. U still interested?
Old 01-27-2012, 07:50 PM
nicksevo's Avatar
amazing car for a stupid low price... wish i could get it but like i said i have to wait till summer but good luck.
nicksevo is offline
Old 01-28-2012, 02:19 AM
Thanks guys, nobody really interested yet, still up for sale guys help me out.
Old 01-28-2012, 02:37 AM
lemons12's Avatar
Can you add cash? Low mileage mint 04 C5Zo6..
Not sure if he would be interested but I will let him know if you are.
lemons12 is offline
Old 01-28-2012, 09:47 AM
Depends on how much cash? what color the car is any mods. etc.
Old 01-28-2012, 02:38 PM
lemons12's Avatar
It is 100% completely bone stock (black outs on the tails is the ONLY mod and they are removable). Bought a while back from a collector. It is Millennium Yellow and perfect. Bought it with 11,XXX miles and now has very low 20K miles.
He paid roughly 25-27K for it FWIW.
lemons12 is offline
Old 01-28-2012, 04:24 PM
Melon's Avatar
Would you take a 91 mustang of as trade has a dss level 10 block all forged lightend 410windsor afr225 comp came roller came 240/244@.050 trickflow r intake accufab 75 mm throttle body griddle kooks 1 ⅞ to 3inch has about 5000miles on it
Qa1 tubular k member adjustable a arms coil over with strange 10way struts sub frame connectors 8 point cage
Welded 8.8 rear with 9inch ends mooser 31 spline axles spool Mac gridle adjustable upper control arm battle box upper and lower torq boxes. Transfer wise is a t56 magnum with quick time bell with sluing flywheel and a custom clutch from promotion transfer set up has less than 1000miles only bad thing about the car is the paint is bad starting to orange Peel bad. I have most of the recpits car went 10.70s at 125 with a c4 and drag radials have not Beem to track sense 6 speed car also made 445whp 467wtrq has autometer fuel Psi oil paid water temp oil temp also has measure 55gpm. Electric watter pump Griffin Rad and dual premacool fans if wanting to trade I will drive it to you in spring when salt is off road
Melon is offline
Old 01-29-2012, 06:35 AM
Come on guys this is a steal
Old 01-29-2012, 07:40 AM
bufmatmuslepants's Avatar
727 rwhp through a 10 bolt?
bufmatmuslepants is offline
Old 01-29-2012, 07:45 AM
Yea it wasn't a absolute track car. The 10 bolt does have moser axles and 410 gears.
Old 01-29-2012, 09:33 AM
hiram007's Avatar
hiram007 is offline
Old 01-29-2012, 03:26 PM
lemons12's Avatar
Are you interested in the Z and adding cash?
lemons12 is offline
Old 01-29-2012, 04:59 PM
Italiankid77's Avatar
Any 1/4 times??
Italiankid77 is offline
Old 01-29-2012, 05:48 PM
kyles2000z's Avatar
If the baby is the reason for the sale.....trading for soemthing else wouldn't fix the baby part!
kyles2000z is offline
Old 01-29-2012, 06:15 PM
LeonbergerG's Avatar
Nice ride. I think I should go refinance my house..
LeonbergerG is offline
Old 01-30-2012, 04:56 AM
jks hugger orange ss's Avatar
Where in sc are u located?
jks hugger orange ss is offline
Old 01-31-2012, 10:51 AM
Blinkn's Avatar
I hate how mch i love this car. & its a good deal 2. Man it sux being poor...
Blinkn is offline
Quick Reply: SOLD!! 2000 Trans Am 727Rwhp (Mecham Clone)
