Alternator only kit?
If you mean a kit to run the alternator without the power steering pump. Some one does make a pulley kit for that. I just put in an idler pulley above the alternator to get better belt wrap on the water pump.
1 Post
BMR sells an alternator only bracket that mounts the alternator on the bottom of the drivers side engine block. I don't know what people are saying about belt wrap but to me alternator only means you have an electric water pump and only the alternator needs a belt.
It was a factory LS1 pulley bought at NAPA. Check out this link https://ls1tech.com/forums/conversio...lternator.html
