What exactly is a Speed Density Tune
George
Normally everything stays in a SD tune unless you are running a Open loop SD tune then your o2's go also. SD tunes are usually used in FI builds and stroker high HP application.
There is a ton of threads as to what is better etc in this section and online if you want to read in detail.
Thanks Bill
I want be running a MAF with this Super Victor and 4150 TB. Race only car.
I've read alot on the SD tunes, but still confused alittle. Most people are worried about idle and street driveability with SD tunes, that I've read. I don't care about driveability.
This car will stay between 5000 to 7000 rpms most of it's time.
Thanks Bill
